Ecotect, DIVA and Radiance
HI All,
I have installed the DIVA for Rhino plugin and since there I can no longer
run radiance grid analysis directly from Ecotect. I am getting the following
error message in the dos window:
"rtrace: fatal - command line error at '-sj'
Which then results in no data being written to the grid file.
In addition I cannot recall how to reinstall everything to its original
state as it was operating before installing DIVA for Rhino.
Any help with this would be appreciated.
Bayanda
BAS (UCT)
Green Star SA Accredited Professional
PJ Carew Consulting
3rd floor 71 buitengraght Cape Town 8001
tel: 021 426 4051 fax: 021 426 5050 cell: 083 335 9365
<mailto:[email protected]> [email protected] <http://www.pjc.co.za/>
www.pjc.co.za
Hi Bayanda,
I don't know if this is of any help (I never worked with DIVA), but your problems reminds me to the release note of Radiance 4.1 which says that the -sj option has been changed to -ss:
****** COMPATIBILITY CHANGE ********
Changed -sj (specular jitter) option to something called specular
sampling (-ss), which if set less than 1 has the same behavior as
the old -sj, but when set greater than 1, spawns multiple ray
samples from semi-specular surfaces.
For details see: http://radsite.lbl.gov/radiance/refer/Notes/ReleaseNotes.html#Version%204.1
My best,
Iebele
Op 4 apr. 2012, om 10:50 heeft Bayanda Mpauli het volgende geschreven:
HI All,
I have installed the DIVA for Rhino plugin and since there I can no longer run radiance grid analysis directly from Ecotect. I am getting the following error message in the dos window:
In addition I cannot recall how to reinstall everything to its original state as it was operating before installing DIVA for Rhino.
Bayanda
BAS (UCT)
PJ Carew Consulting
[email protected] www.pjc.co.za
It looks like the version of Radiance shipped with DIVA is incompatible with the one required by Ecotect. Since the version shipped with DIVA is the more current, I am not sure what to do. Do you have an Autodesk support contract for Ecotect?
Randolph
On 2012-04-04 07:50:31 +0000, Bayanda Mpauli said:
HI All,
Bayanda
BAS (UCT)
PJ Carew Consulting
Randolph M. Fritz
