Ahem... could it really be that anyone is not aware of
the easy way to convert a DXF file yet?http://www.schorsch.com/download/dxf2rad/
And if you're really *still* using torad for exporting
from Autocad, please have a look at Radout instead!
I find torad a useful tool still - note that I have upgraded the torad.lsp
code to work perfectly well in AutoCAD 2000. Yes - if your file is a DXF to
start with, the dxf2rad is a good tool, but I often start with DWG files,
meaning that I would have to use AutoCAD anyway to convert to DXF. I
realise that something like radout probably is more robust and converts more
entity types, but torad usually works fine for me - so if it isn't broke,
don't fix it...
Hope you find the Crossroads program of some use - I found it while trying
to solve the exact same problem a couple of years ago...
Jeff
Jeff Shaw
ArupLighting
13 Fitzroy Street
London W1T 4BQ
Tel +44 020 7755 2383
Fax +44 020 7755 3743
Web http://www.arup.com/
