Hi everyone,I have a question about DGP. I want to assess the DGP at a certain point in my building caused by the façade across the street. What I have done is running the simulation DGP simulation, then setting the facade as a black body and run it again (this way I account for everything but the façade). Then I subtracted both results to get the DGP produced by the façade. However, I am kind of suspecting that DGP is not that simple (since it also considers factors like contrast) and one cannot operate with it in that way.If so, can someone think of an alternative way to measure glare produced by a certain elemhent?Thanks in advance, Alejandro
Hi Alejandro,
One option is to run the evalglare program with the -d and -c parameters.
> evalglare -d -c check.hdr image.hdr
This will do two things: (*1*) the -d option will give you a list of all contrast-based glare sources, including reflections from your facade; (*2*) the -c option will colour the separate contrast-based glare sources randomly in the check.hdr file. You can even plug the values from 1 into the contrast half of the DGP equation.
Of course running the calculations either with the building as a black hole or (more realistically) as not present at all produces some comparative value as well.
Alstan
On 4/22/2015 9:58 PM, Alejandro Pacheco Di�guez wrote:
Hi everyone,
I want to assess the DGP at a certain point in my building caused by the fa�ade across the street.
What I have done is running the simulation DGP simulation, then setting the facade as a black body and run it again (this way I account for everything but the fa�ade). Then I subtracted both results to get the DGP produced by the fa�ade.
Thanks in advance,
Alejandro
Hi Alejandro,
the question is not that easy... Usually you compare two cases and then look for the differences (as you want to do)
But the first question is, what is the "reference" you want to compare to. A comparison with a black surface is definitely not "fair" - it overestimates the influence of the facade. I would rather use a case without an opposite building or using one with a diffuse surface (but then again, what color do you assume as "reference"... if you are on greece islands, this would be white around 70% reflectance, in northern Germany red brick around 20% reflectance...). So not to end in discussions about a meaningful reference, I would go for the "no building" reference. So then you have two cases and you end up with two different values, so you can state "the facade causes an increase of the DGP by XX compared to an unobstructed view to the surrounding.
If you are dealing with specular reflections of the sun on your facade, then you have to be careful to use a larger image size. (at least 1200x1200, better 1500x1500 in order to have enough pixels to see the reflexion of the sun)- even evalglare is getting very slow. and be careful about pixel sampling, jittering settings and the -lw limit.
And just to be sure - don't use any of the existing simplified methods to calculate DGP (they are not based on a full rendering), because they are based on illuminance calculations using rtrace -I - in that case you will miss the specular reflection of the sun (it doesn't matter if it is glass, plastic or metal) if you don't use a special material mix on your surface containing also the mirror material.
And finally: Be aware, that DGP is just a measure for discomfort glare INSIDE a building. It does not include disability glare and is also no measure for discomfort glare OUTSIDE a building, where you have much higher adaptation levels.
Jan
Am 4/22/15 um 4:21 PM schrieb J. Alstan Jakubiec:
Hi Alejandro,
> evalglare -d -c check.hdr image.hdrThis will do two things: (*1*) the -d option will give you a list of all contrast-based glare sources, including reflections from your facade; (*2*) the -c option will colour the separate contrast-based glare sources randomly in the check.hdr file. You can even plug the values from 1 into the contrast half of the DGP equation.
AlstanOn 4/22/2015 9:58 PM, Alejandro Pacheco Di�guez wrote:
Hi everyone,
Thanks in advance,
Alejandro
http://www.radiance-online.org/mailman/listinfo/radiance-general_______________________________________________
Dr.-Ing. Jan Wienold
EPFL ENAC IA LIPID
LE 1 111 (Office)
Phone +41 21 69 30849
