Dear list,
I plan to build several radiance models of Alzheimer care facilities in
preparation for a field study examining daylight exposures and cognitive /
health outcomes in partnership with a colleague in health sciences.
The radiance work is intended to supplement the data collected from
physical sensors to provide greater insight into 24-hour patters of light /
dark.
I would like to measure the surface optical properties (color,
reflectance) of the walls / ceilings and floors etc.
I am aware of two devices that have been used to do this.
1) The first is the X-rite Colormunki (actual name of product) that Michael
Donn was using while visiting LBNL.
The second is the Minolta CM-2002 Spectrophotometer used by Mehlika Inanici.
If anyone has experience with this task who can provide some comments on
their approach it would be appreciated. (Michael and Mehlika, i will likely
contact you directly!).
-Kyle
Kyle Konis, AIA, Ph.D
Assistant Professor
School of Architecture, WAH 204
University of Southern California
Los Angeles, CA 90089-0291
http://arch.usc.edu/faculty/kkonis
I ASSume you are happy with simple spectral info (RGB) for your Radiance model? If so you could do this on the cheap and easy with a MacBeth color chart and the macbethcal utility in Radiance. Just sayin'.
P.S. I know we're all lighting peeps, but recent research suggests the way to avoid Alzheimer's is cholesterol. Brain by bacon!
P.P.S. I may have oversimplified the current research, a tad.
Sent: Wednesday, January 29, 2014 11:54 AM
Subject: [Radiance-general] Device suggestions for measuring surface color and reflectance in the field
Dear list,
I plan to build several radiance models of Alzheimer care facilities in preparation for a field study examining daylight exposures and cognitive / health outcomes in partnership with a colleague in health sciences.
The radiance work is intended to supplement the data collected from physical sensors to provide greater insight into 24-hour patters of light / dark.
I would like to measure the surface optical properties (color, reflectance) of the walls / ceilings and floors etc.
1) The first is the X-rite Colormunki (actual name of product) that Michael Donn was using while visiting LBNL.
If anyone has experience with this task who can provide some comments on their approach it would be appreciated. (Michael and Mehlika, i will likely contact you directly!).
-Kyle
Assistant Professor
