DEM to .rad pipeline
Hello Radiance community,
I am very new to radiance and thus this may come across as a novice or
naive question. I hope to use radiance to model daylight on exterior
surfaces. The geometry I work with are DEMs typically coming in raster
(geotiff) format.
Can anyone suggest a most efficient (or path of least resistance) workflow
to translate the DEMs into Radiance scene description file?
I can convert the raster DEM into one of the many vectorized mesh-based
formats (i.e., some type of CAD format); but am hoping the community may
have some insight here to help narrow this down for me (best CAD file
type). It seems a triangle-mesh file would be ideal; wonder if there is
software that export this file type?
Any advice, references to plug-ins or tips would be most appreciated!
Sincerely,
Ian
*I A N S E I F E R L I N G *PhD
Postdoctoral Fellow | MIT Senseable City Laboratory
<http://senseable.mit.edu>
77 Massachusetts Avenue 9-209
Cambridge, MA 02139 USA
ianseiferling.com <http://www.ianseiferling.com/>
Best is save to an obj file and then import as mesh with obj2mesh
G.
On 31 Jan 2017, at 22:36, Ian Seiferling <[email protected]> wrote:
I am very new to radiance and thus this may come across as a novice or naive question. I hope to use radiance to model daylight on exterior surfaces. The geometry I work with are DEMs typically coming in raster (geotiff) format.
