Danaplon glazing - Glass or Trans?
What would the best way be to model Danaplon translucent material (http://www.danpalon.com)
For example the 4mm (http://www.danpalon.com/eng/home/portfolio/03/default.asp?ContentID=111):
Walls - *1*
Thermal insulation factor - *5.36* W/m2°C
Moment of Inertia with U Connector - *7.4x10^5 * mm^4 /m
Minimum cold bending radius - *2.9* meter
Panel width - 592mm
Module width (with spacer) - 600mm
Optical properties:
Clear
Ice
Opal
Bronze
Blue
Green
Grey
Reflective
Visible Light
Transmission
89%
55%
40%
38%
64%
75%
41%
20%
Solar Heat
Gain Coefficient
0.81
0.61
0.48
0.50
0.75
0.72
0.58
0.28
My attempts:
# Translucent Sheeting Danpalon_Sheeting_Opal_4mm
void trans Danpalon_Sheeting_Opal_4mm
7 0.4 0.4 0.4 0 0.02 1 0
# Danpalon_Sheeting_Opal 40% light transmittance
void glass Translucent_Glass_Danpalon_Sheeting_Opal_4mm
3 0.43621868 0.43621868 0.43621868
I would assume that the thicker products (more walls) should not be modelled as glass but maybe via the optics program, though I have no idea how/what to feed that program.
Unfortunately the manufacturer has very little technical information available.
Regards
*Terrance McMinn*
Terrance,
Your trans material for the Opal version doesn’t include any reflectance. Assuming that the visible reflectance is similar to the 35% solar reflectance for this product, and all transmission is diffuse, the result would be:
7 0.75 0.75 0.75 0 0 0.533 0
If you want to have this be a combination of specular and diffuse transmittance, then the last number is the fraction of light transmitted that is in the specular component. You can add some roughness by changing the second zero in the fourth line.
Rick
Sent: Wednesday, October 21, 2015 2:28 AM
Subject: [Radiance-general] Danaplon glazing - Glass or Trans?
Walls - 1
Thermal insulation factor - 5.36 W/m2°C
Moment of Inertia with U Connector - 7.4x105 mm4/m
Minimum cold bending radius - 2.9 meter
Panel width - 592mm
Optical properties:
Clear
Ice
Opal
Bronze
Blue
Green
Grey
Reflective
Visible Light
Transmission
89%
55%
40%
38%
64%
75%
41%
20%
Solar Heat
Gain Coefficient
0.81
0.61
0.48
0.50
0.75
0.72
0.58
0.28
My attempts:
Regards
Terrance McMinn
Hello Rick,
Off List questions...
This is very helpful.
From the catalogue for 4mm Danpalon Opal
LT% = 40 - LT % of visible light transmission (400 - 700nm)
ST% = 44 - ST % of total solar radiation transmission (300 � 2800nm)
SR% = 35 - SR % of total solar reflection (300-2800nm)
SHGC = 0.48 - SHGC Solar Heat Gain Coefficient.
I am wondering how you arrived at the 7 parameters: red green blue spec rough trans tspec
Actually (red green blue and trans)
Regards
*Terrance McMinn*
Please consider the environment before printing this e-mail.
Notice - This message contains confidential information intended only for the exclusive use of the addressee named above. No confidentiality is waived or lost by any mistaken transmission to you. If you have received this message in error please delete the document and notify me immediately.
Any opinion, text, documentation or attachment received is valid as at the date of issue only. The recipient is responsible for reviewing the status of the transferred information and should advise me immediately upon receipt of any discrepancy.
On 21/10/2015 8:45 pm, Richard Mistrick wrote:
Terrance,
Your trans material for the Opal version doesn�t include any reflectance. Assuming that the visible reflectance is similar to the 35% solar reflectance for this product, and all transmission is diffuse, the result would be:
Rick
*Sent:* Wednesday, October 21, 2015 2:28 AM
*To:* [email protected]
*Subject:* [Radiance-general] Danaplon glazing - Glass or Trans?
Walls - *1*
Thermal insulation factor - *5.36* W/m2�C
Panel width - 592mm
Optical properties:
Clear
Ice
Opal
Bronze
Blue
Green
Grey
Reflective
Visible Light
Transmission
89%
55%
40%
38%
64%
75%
41%
20%
Solar Heat
Gain Coefficient
0.81
0.61
0.48
0.50
0.75
0.72
0.58
0.28
My attempts:
Regards
*Terrance McMinn*
Terrance,
I have a spreadsheet to process the equations for this. See http://radiance-general.radiance-online.narkive.com/ugCzWij7/accurate-definition-of-trans-material for the equations.
I think the spreadsheet is included in our DAYSIMps installation if you download and install that software.
Rick
Sent: Wednesday, October 21, 2015 1:03 PM
Subject: Re: [Radiance-general] Danaplon glazing - Glass or Trans?
Hello Rick,
ST% = 44 - ST % of total solar radiation transmission (300 - 2800nm)
Regards
Terrance McMinn
Terrance,
Your trans material for the Opal version doesn't include any reflectance. Assuming that the visible reflectance is similar to the 35% solar reflectance for this product, and all transmission is diffuse, the result would be:
Rick
To: [email protected]<mailto:[email protected]>
Walls - 1
Panel width - 592mm
Optical properties:
Clear
Ice
Opal
Bronze
Blue
Green
Grey
Reflective
Visible Light
Transmission
89%
55%
40%
38%
64%
75%
41%
20%
Solar Heat
Gain Coefficient
0.81
0.61
0.48
0.50
0.75
0.72
0.58
0.28
My attempts:
Regards
Terrance McMinn
