CVS, ANSI, C++
I didn't cross-post this to radiance-general...
> Georg Mischler wrote:
This just reminds me of another problem that we'll have to solve
in this context. Since Windows doesn't support NFS file locking
(and neither did cygwin, last time I looked), we'll need to find
a better solution for concurrent access to ambient files. I can
think of two portable ways to do this: Either we invent a file
based locking mechanism, or we establish a seperate server
process that accepts network store and retreival requests by the
actual simulation processes. The latter would be more technicall
involved, but probably a lot more robust. Any thoughts?
Ewww. Can't we just say that if you want to do parallel rendering, you need to install Unix?
> Autoconf...scares me. It's one of the most difficult scripting
> languages and it actively encourages #ifdef-laden code. Personally, I
> favor the Kernighan and Pike (*The Practice of Programming*) approach
> to portability; write the base code portably, and bottle up the OS
> dependencies in separate libraries and APIs.
I don't think that those two approaches are mutually exclusive.
Some more complex dependencies certainly belong into seperate
modules with a thick layer of barbed wire around them. But there
are also many other small variations and bugs among different
systems with no clear borderlines between vendors, kernel and
library versions, etc. Keeping track of those without a tool like
autoconf is a real pain for both developers and users.
Have you had a look at the makeall script lately? This is
complexity that the user has to handle when something goes wrong.
Autoconf is generally a one-time effort, that only needs to be
handled by one or two of the developers. Once that is done, the
trusty mantra of "./configure; make; make install" just magically
works on pretty much any system, whether its specific quirks have
been cataloged before or not. Not every user can grant Greg ssh
access to solve compile problems, and Greg probably wouldn't have
the time to do this for every user anyway.
The Radiance sources are currently littered with hundreds of
instances of preprocessor symbols referencing more than a dozen
individual operating systems. This has almost worked yesterday,
it's already breaking today with very current systems, and it's
garanteed to break in the future, unless someone constantly keeps
a list of all the systems out there and their specific bugs and
other nonstandard behaviour. I will chose #ifdefs of the form
"HAS_<feature>" any time, against the alternative of multiple
nested OS specific conditionals in the same place.
OK, that's a bit of an exaggeration. I did a quick grep of the source tree, and I found 8 instances of system-dependent code in 6 files. These are typically limited to a #define or a declaration or two, and I expect that we could eliminate most of these with a little effort -- much less than it would take to change over to a HAS_<feature> sort of coding strategy. I've found that by doing some homework, it is usually possible to find a solution that works on all systems without any conditional compiles. The ones that are in there now are either necessary because there aren't any general solutions, or more likely, they could be eliminated. The least-common-denominator approach to portability is still the best in my opinion. You miss out on a few features on a few systems, but you get a more consistent result in the end (with cleaner code).
> Peter Apian-Bennewitz wrote:
> > However, that interface is not changed solely by prototyping functions.
> > Doing more than that risks new bugs- well, we'll get them out. Maybe
> > there's a core structure between just-prototypes and a full rewrite ?
> Hmmmm...Radiance plug-ins. Most Unices support some version of
> dynamic loading these days. Windows does. I don't think Plan 9 does...
Prototypes and the elimination of global variables will make the
*internal* interfaces of Radiance a lot clearer and more obvious
than they are right now. After that, it will be much easier to
isolate those parts that need to be changed to better accomodate
any present or future extensions, and the risk of breaking all
the rest when doing so will become much smaller.
I support this suggestion whole-heartedly. The global variables currently in use in the renderers could be eliminated with a single structure and a reference to it in the ray struct. In principle, the bulk of the renderer could then be consolidated into a library, which could be multi-threaded with a bit more work....
> Now, I'm interested in ways to standardize the GUI API. In my
> opinion, it would be useful if we could customize ximage and rview to
> native OS conventions easily, perhaps by providing an OS specific
> library. It might also be useful to embed the core rendering tools in
> a dynamic loading environment. But, again, I don't know what it would
> take.
You're not the first one to think that thought.
In the end it won't really take a lot of effort, but only after
the above steps have been taken. Despite all its shortcomings,
the Windows version of rview already points into the right
direction here, by demonstrating approximately where the
interfaces between the simulation core and a display framework
should be placed. Unfortunately, the existing implementation is a
horrible mess, due to the difficulties of integrating the current
Radiance code on one hand, and some other obstacles the original
developers were facing on the other. I realize that most of you
haven't seen those sources yet, so you'll simply have to take my
word for it... :wink:
I haven't seen this code, either, and from what you say, I'm not sure I want to... I thought I had defined an interface for rview pretty well in rt/driver.h. This is where I began when I wrote different drivers. (There was a little-used NeWS driver at one time, as well as one for Suntools -- anyone remember those systems?) As for ximage, this program was meant to be replaced in its entirety, not built upon. I assume that's what they did for Windows, but I don't know. The programming interface for image display is the Radiance picture format!
A P.S. on my previous post. When I did the grep for system dependencies, I was only looking for conditional compiles specific to one system, and I sort of missed Georg's point, that the makeall script contains a lot of system-specific stuff in it. I agree, though I'm continually surprised by how few problems this actually has caused over the years. Still, I imagine a HAS_<feature> approach could be better in the long run.
Be that as it may, if you look at makeall, you will see that the things I test for are not the sorts of things that autoconf tests for. For example, whether the system qsort() routine works, or if the system malloc() function can be overridden. The other symbols I commonly define are BSD, for systems with good BSD library support, and DCL_ATOF, for systems that don't declare atof() in the expected place. I suspect I could eliminate DCL_ATOF by including stdlib.h at this point, but I would have to make a few other changes to allow this. If we could eliminate the other 8 system defines I used, that would leave BSD as the only remaining symbol of any consequence.
There are at least two efforts which happened in parallel to Greg's development of Radiance 3.4 which I think will be useful for the overall efforts to streamline portability of Radiance. As part of the LDRD (Laboratory Directed Research and Development) efforts to develop YAPR (Yet Another Parallel Radiance), David Robertson separated out all of the platform-specific and operating system code into a set of independent files. In order to do this, he de-IFDEF'd one particularly nasty piece of code. And, to some extent, he also ANSI-fied the code. I know that Greg is hesitant to blindly accept all of what David Robertson contributed, but I think it ought to be evaluated by someone to see what can be salvaged. There are a great many parts of Radiance which have not changed with Greg's latest release. And, seeing the David Robertson in person, I actually have some faith that he did his work carefully and thoroughly. He developed a test suite and repeatedly tested his version against the original to ensure that it was running the same. No doubt there will be annoyances. For example, he globally renamed some of the variables. He mentioned, for example, some two-letter variables that kept appearing and confusing him.
The Radiance licensees all have the source code for this "LDRD" version of Radiance on the CD-ROM.
Then, Ken Revzan took this code and put it into MicroSloft Visual C++. It compiled with relative ease and he made rapid progress. In our earlier efforts, we looked at Cygwin extensively. I favor the MS C++ compiler for the reasons mentioned earlier. Greg might even like the command-line version of the complier. <cough-cough> It understands makefiles with little modification.
In developing the Desktop Radiance "Winimage" program, we did not use the ximage core program...we did use the Radiance Image File interfaces. We first built the viewer on top of GL for Windows. Ken Revzan then re-implemented in with the native Windows driver because it was faster and less buggy.
The Desktop Radiance "Interactive Renderer" or Win-rview was built using the ASCII-interface to rview, as does (did) rshow. Ken Revzan learned a lot from Peter by looking at rshow. However, Ken failed to implement a proper trap for some high-level interrupts in rview. This continues to plage the original version, but I think George has fixed many of these problems. Last I remember, George declared that it was, alas, fundamentally flawed and needed to be re-written. But, I remember that Ken Revzan complained about the underlying rview code because it did things that C++ doesn't like. It was either related to long-address jumps or something related to the handling of interrupts for the indirect calculatoin. So, this might be another thing to consider.
And for the wish-list, there was a paper submitted to SIGGRAPH in 1998 by a guy (?) from Intel that used a type of Fourrier transform analysis of the image plane--as it was being developed--to drasitically reduce the required sampling density. He claimed to be able to sample only 7% of the image plane and acheive identical results. Last I heard, Intel planned to patent his approach, but if anyone has not read his paper, they could probably re-implement it without infringing upon the patent. Or, perhaps Intel would donate it to the open source effort.
-Chas
  Greg Ward <gward@lmi.net> wrote: A P.S. on my previous post. When I did the grep for system
the years. Still, I imagine a HAS_ approach could be better
in the long run.
Radiance-dev mailing list
http://darkside-animation.com/mailman/listinfo/radiance-dev
Do You Yahoo!?
Sign-up for Video Highlights of 2002 FIFA World Cup
...and a P.S. to my previous post. Windows networking has a very robust file locking mechanism that is implemented in the public domain code called "Samba". In an earlier version of Radiance for Windows built on top of Cygwin, we implemented the Samba file protocols into the Radiance ambient code and into rpiece. They worked very well. I could dig up the original contributor and his code very easily. Since Samba is available for just about every unix platform, we could IFDEF a few lines of code that would allow the user to select which protocol to use. In my use of samba-locking, I've never encountered the kinds of problems I've experienced with NFS lock manager. One of the nastiest is that NFS locking is implemented differently on different operating systems. One can not, for example, render an image on a heterogenous network of SGI's and Linux boxes.
-Chas
Do You Yahoo!?
I accidentally sent this to Greg directly instead of to the list.
Peter, could you set the Reply-to to the list for this one as well?
Hehe...
If you were asking me for my purely emotional response, then
you'd probably like my answer better than the one you'll actually
get. But I think we should face reality and accept that in the
near future, most people using Radiance will be sitting in front
of Windows boxes.
They may well be sending long simulations to some linux cluster
in the basement, but their CAD system will probably run under
Windows, and having to switch back and forth more of a pain than
working with the "wrong" system all the time. Others will really
distribute stuff across their Windows network, as not everybody
may have the funding for establishing a parallel infrastructure
just for Radiance.
Maybe what we really need is some kind of switch that allows to
access different locking mechanisms depending on the situation. I
didn't check in detail, but I assume there are two functions, one
for fetching ambient data and one for storing it. Such a very
narrow interface lends itself relatively well to this approach.
It's not that I can easily pull a good file or server based
locking strategy out of my ears, but I think it would be worth a
little effort. We have had enough problems with NFS locking in
the past to appreciate the advantages that a working and truly
portable solution will bring.
I wasn't really exaggerating that much as far as the numbers go.
But of course I didn't check how many of those are really still
needed or could be eliminated in other ways. I'm not sure, for
example, how many of the MSDOS special cases are really still
required on modern Windows systems, and most of the UNIX
conditionals may fall away with the reverse argument. Those and
BSD seem to be responsible for more than half the OS specific code.
I also didn't mean to insinuate that we need autoconv right now
and at any price. I think we'll know more about what we really
need after ANSIfication, as this may already eliminate quite a
few dependencies. If we then end up with so little that a
homebrew script gets us the same result, so much the better. The
differences between BSD and SYSV have been reduced to a large
degree by the ongoing implementation of the posix standards by
most vendors.
I was actually thinking about a slightly finer granularity, but I
guess we'll see what makes sense when we get there. One of the
more interesting tasks might turn out to be the elimination of
exit() calls in code that is considered part of a library. I
don't think there's any part of Radiance that currently hesitates
to kill the whole process whenever something goes wrong, which
would be very surprising for a program using such a library.
want to...
Well, it's C++ code for Windows, apparently written by someone
who didn't bother to read the very decent documentation about the
system APIs coming with his compiler and IDE. I'm clearly no
expert in Windows programming (let alone in C++), but there's no
feeling of loneliness in that corner...
I couldn't say for sure. My primary fight was on the Windows
side, to turn the whole thing into a conforming and well behaved
program (with at least partial success). As far as I remember
right now, they directly hooked into the raytracing routines.
One of the trickier problems is how to make the raytracer return
prematurely out of its recursive ambient calculations upon user
input. The lack of this possibility (and thus often significantly
delayed response) can also be quite annoying with ximage. On Windows
this becomes a serious issue, as you can't just kill a program
without the risk of losing a bunch of system resources.
I'm not sure if I understand the concept behind driver.h
correctly yet. It looks like it wants to do all the event
handling itself, and reduces the "driver" to subordinate tasks
like providing mouse coordinates etc. Modern window management
systems rather lend itself to the opposite approach, where the
user interface runs the event loop and calls the simulation code
in the background (possible in a seperate thread). This makes it
possible to offer menus and other interaction possibilities,
which gives the user better control about what happens.
The possibility to interrupt the simulation at any point in its
recursion is mandatory to garantee this responsiveness. As far
as I could figure out, this possibility isn't currently
implemented (and the implementation in winimage is not as clean
as it should be). I haven't checked if the holodeck stuff does
anything different in that regard.
The programming
Hmmm... and reinvent all the tonemapping stuff?
-schorsch
I totally agree with Georg's comments about Windows machines and networking--of course. His idea for a run-time flag for which locking mechanism to use is great, but the default should be the one that works. But, fetching data is not a problem for any of the NFS implementations because even the broken ones do that correctly. But, a re-implementation is not necessary--samba code and Radiance implementation is already done, available and working.
Some of the MSDOS special cases were necessary when dealing with the headers from Unix versus Windows image files.
-Chas
Do You Yahoo!?
Greg Ward wrote:
Having dealt just a little with Windows networks, I have to say that my
interest in supporting them is identically 0 over all time and space.
I'll leave it to you and others who think it worthwhile.
Very understandably. I'd like to try to stay away from any
Windows specific stuff as much as possible myself. Any solution
should be either file or IP based, to make it portable across
all platforms.
Another reason to use a file lock manager rather than a server process
besides simplicity is that the lock manager is robust to individual
systems going down (or should be), whereas everything dies if your
server process dies. What about Chas' suggestion of offering Samba as a
substitute lock manager?
The lock manager ultimately dies with the machine where the
locked file resides, which is just as good or bad. Ideally, any
other server process would run on this same machine as well. Only
when this isn't possible will there be two seperate points of
failure.
I'm not sure yet what Samba exactly does here, apart from the
fact that it involves yet another extra server process. One one
side, Samba offers the standard Windows network locking API to
processes connecting from that end. And it looks like it *can*
translate those into flock() calls on the unix side. Does this
mean that unix processes accessing the same file per NFS would
see the lock too?
Chas, is this code included in the Radiance for Windows sources I
have or was it added later? Because I'm pretty sure that my
version corrupts the ambient files on concurrent access.
The ultimate goal should be that every process on every OS type
can access the same file without getting in each others way.
> One of the
Ah, yes. I agree -- although I usually call quit(), which then calls
exit() if it isn't overridden by the calling program. The only way to
avoid exit() is with a long jump, however, and this is not a generally
recommended practice, so it remains a problem.
One of my modifications to winrview was to establish a safe
return path from very deep recursion levels when user interaction
stops the current simulation. This may involve a few additional
return value checks, but I think in this specific case those were
already in place. Similar scenarios, in the worst case with an
extra flag somewhere to indicate an error condition, should be
possible in most if not all places where exit/quit are invoked.
But I think we're discussing pretty far in future mode here already...
If the ambient calculation is the only barrier to responsiveness in
rview, it wouldn't be too difficult to query the value of some variable
set asynchronously by the caller and make a hasty retreat.
Yup, exactly.
However,
we'd have to work long and hard before we got the renderer code into
thread-safe shape.
Maybe, maybe not. There are at least two levels of thread safety.
One is to have the critical code running independently in its own
thread *once*, which is no problem as long as there aren't any
global variables. The other would be to allow several instances
running in parallel threads, which in addition requires the
elimination of all static variables in functions. I think both
conditions could be met quite easily when all state (including
any stop condition flags that the parent thread might want to
set) is encapsulated eg. in the ray struct. Future mode again,
though.
Another option is to use the Unix signal facility to
send an interrupt to the rendering process, causing premature
termination of any ambient calculation in progress. This wouldn't
require much coding effort at all.
Unfortunately, signals and Windows don't match very well...
Another, possibly better solution would be to have the renderer call a
global "checkInput()" routine every so many rays, which is the way rview
is _supposed_ to work but doesn't, simply because the call to
checkInput() is handled at too high a level. If we moved this into the
low-level raytrace() routine, I think we'd have responsiveness licked
without having to change to a background rendering process. I might
even give this a go to try it out.
Whichever stopping signalization is chosen should indeed be
checked somewhere down there. Winrview currently does this at the
beginning of ambient(), sets a flag for the original caller (not
really necessary), assigns zero values to the current rgb set
(should probably use the ambient values instead), and returns.
I don't know if this is the optimal place to do this, but it
worked well enough for me at the time.
-schorsch
failure.
It seems like establishing a Radiance locking manager--perhaps just a
problem which managed the global ambient file--might be a good idea.
NFS locking doesn't even work on all systems, unfortunately, so that
would also fix that problem.
> > One of the
I believe longjmp() has been standardized in ANSI C, so this has become
safer.
though.
This, plus the previous issue is starting to be a powerful argument
for C++, which solves this problem by making globals into instance
variables and the exit problem with the exception mechanism. With a
hypothetical C++ embedded renderer one could simply instantiate a
renderer object.
OK, then....looking at C++...I think it might be possible. If we left
most of the code as straight C, not using the fancy OO features, only
gathering up--no, wait. We could combine the two solutions. Gather up
the globals into a structure which is referenced throughout the
renderer and use longjmp() to handle exceptions. Then wrap the whole
thing up in a C++ (or Objective C) class. The only issue I can
see--and it is potentially major--would be potential memory leaks.
Randolph
On Thu, Jun 13, 2002 at 10:14:23AM -0400, Georg Mischler wrote:
I see that Peter fixed the reply-to field. Thank you!
The samba code is not part of the current Radiance for Windows release built with MS VC++. It was part of the Desktop Radiance BETA release built with the Cygwin version of Radiance for Windows. Samba works multi-directionally from Unix client to Windows server, Unix client to Unix Samba server, Windows client to Unix Samba server, and of course, Windows client to Windows server. We tested each of these configurations. The kernel of the server cpu will know about the file lock. You ask a good question about what happens when an NFS lock tries to get ahold of the file? I dunno. I presume the lock fails or hangs the client CPU like NFS usually does. :slight_smile: Samba exists for just about every flavor of Unix known, Macintosh OSX included, and it is reliable and has a dedicated open source support staff. Even older Mac's can use a low-cost proprietary solution called DAVE.
If we're going to implement a custom file locking mechanism, then why reinvent the wheel? There have got to be several different open source file locking systems. What about PovRay? They've stolen enough from Radiance...perhaps it our turn to collect. :slight_smile: The Samba mods are just a no-brainer. About 30 lines of code max.
-Chas
all platforms.
failure.
see the lock too?
> One of the
Yup, exactly.
However,
thread-safe shape.
though.
-schorsch
Do You Yahoo!?
I have been using Samba for years, and know it's a reliable and
robust piece of software. In fact, Samba is one of the main reasons
why Microsoft started to run PR campaigns against Linux (and unix
in general), after it could be shown that the "fastest Windows
server in existence" was actually an sgi box...
I would like to avoid reinventing the wheel just as much as the
next guy, but I also don't want to install a monster truck wheel
on a Ferrari (nor the other way round). Most portable locking
implementations in Open Source software seem to be file based,
which is enough reason for checking out why. It's also clear that
locks that are managed by the OS have the potential to be more
reliable, but that generally comes at the price of portability.
If it turns out that Samba really bridges that portability gap,
then I'll be the last one to stand in its way. I just want to
make sure that it does so beyond any doubt, even by looking at
the code, if I have to. If we're lucky, then we can change Gregs
"if you want to do parallel rendering, you need to install unix"
into a "if you want to do parallel rendering on both unix and
Windows at the same time, use Samba". Since Samba aleady is the
most popular connectivity solution between the two, I think we
could live with this restriction.
If I understand the principle correctly, then that would mean
to simply use the standard Windows locking APIs, which are
implemented by the OS for local files, and by Samba when
accessing unix based drives. This would also mean that locking
within either world alone would work by default.
Speaking of that, can anyone authoritatively confirm or reject
the theory that current Linux systems still make problems sharing
locks with Irix? I think that there has gone some work into the
locking code of the more current Linux kernels, but I don't know
for sure if that really fixed all the issues.
-schorsch
PS:
Chas (and possibly others), could you try to make a habit of not
including *all* of the messages you're replying to? Just so we
don't clog the archives with multiple full copies of everything.
[Copied to both lists. Until a few more people--including Greg
Ward!--sign up for radiance-dev I don't feel right about using it
exclusively for this discussion.]
I like what Randolph had to say about code conversion.
Thank you.
I never bothered to take them out because they still seem to compile,
and they don't affect anything (other than taking up a bit of space on
everyone's systems) since Radiance programs that are never run never
interact with the rest of the codebase...
I agree...but I don't see good reasons to preserve some of them
through an extensive rewrite. If they're hard to ANSIfy, I think we'd
be advised to just put them aside.
We're probably looking at a week or two of one programmer's time, and a
few hours from each volunteer. Who wants to step forward?
I can offer a few hours, but exactly when is uncertain.
An afterthought to my last message. The process of ANSI-fication should
probably include a merge of the Desktop Radiance version, at least
insofar as supporting Windows compilation as well.
How do people feel about Cygwin/gcc
<http://sources.redhat.com/cygwin/> under Windows? I don't know the
package, and it probably still needs an MS compiler for the header
files, but otherwise we can use the familiar Unix tools on Windows. I
have, however, only a bit of experience with cygwin, and don't how
well it works for a large project.
Georg Mischler:
It could also be interesting to consider another implementation
framework for all the helper programs circulating around the actual
Radiance core. Some of the csh scripts have been rewritten in C for
Windows, with limited flexibility and robustness. My personal
favourite language for this kind of task would be Python (with some
parts already existing).
I like this very much, but am a bit concerned about requiring all
users to install Python libraries. Also, some users will want other
scripting languages; TCL, Perl, and (gack!) Visual Basic are likely
candidates. Ummm...probably Mathematica.
The problem of platform specific code variations is actually
independent from the ANSI conversion. In part, the ANSI standard was
supposed to reduce those incompatiblities, but succeeded in that
point only to a certain degree. I have no experience with GNU
autoconf myself, but maybe that would be a reasonable way to
eliminate the need to actually know which platform has what kind of
quirks.
Peter Apian-Bennewitz <apian@pab-opto.de>:
Thoughts on a rewrite were founded on the limited and cumbersome
"interface" for extending the core rendering.
take.
On Sun, Jun 09, 2002 at 08:02:07AM -0700, Greg Ward wrote:
Randolph Fritz
Eugene, Oregon, USA
I din't even know that list existed. When was it created?
I'm also posting to both for the moment, but I'd suggest that we
move this discussion over completely from now on.
Cygwin is a wonderful hacker's tool, but I wouldn't recommend it
to the typical Windows user. I think the MS header files can be
downloaded somewhere, so that wouldn't necessarily be a problem.
But there are still a lot of issues that require custom coding
for Windows, as cygwin doesn't support all the unix APIs, and
some are only supported in relatively hackish ways. Apart from
that, as much as I hate to admit it, the MS compilers still
optimize a lot better than any gcc version I have seen so far.
Python is trivial to install on every supported platform (which
are a lot more than even Radiance supports). Most unix systems
nowadays come with a preinstalled Python interpreter, (plus Tcl
and Perl, of course). The reason why I prefer Python in this
context is that it can be easily understood even by normal users
(in contrast to Perl), and that it has a very robust and stable
feature set, so that programs usually don't break with the next
release (in contrast to Tcl, as Gregs heroic efforts with trad
have demonstrated).
On top of that, a large body of related code in Python already
exists, parts of which may eventually be released as Open Source
as well (tough I can't make any promises just yet). In any case,
this is more a general thought for the future than an immediate
requirement. The basic core of Radiance should probably continue
to work without too many external dependencies. But a second
layer of tools could profit a lot of some improved flexibility
and portability.
Anyone who wants to use proprietary stuff like VB is always free
to do so, but I'm not sure about the chances of such code to be
included in the core distribution of Radiance even in the long run.
The default compile and installation should probably be designed
for static linking, but on most systems it will be relatively
easy to generate dynamic options from there. Creating dynamically
loadable extension modules for Python from existing C libraries
is almost trivial, btw. (the image converter module in Rayfront
is just one practical example involving Radiance code).
take.
-schorsch
