Creating a void in a wall
Dear All,
Is it possible to create a void in a wall instead of creating polygons
around a void?
For instance:
for creating a window we can generate polygons surrounding the window and
then a polygon which refers to glass. now I want to know instead of doing
that is it possible to define a wall as a polygon and create a window on
the wall without manipulating the wall's polygon.
It might have a simple solution.
Best Regards,
Ehsan
Hi Ehsan,
nothing is impossible with Radiance :wink: You can get a hole into your wall without modifying the underlying geometry of the wall polygon. One way is to cut out the opening with a box of material antimatter. Everything within that box will become invisible. This means that you can also not place window frame and glass inside. The second option is to apply a mixfunc modifier to your wall. At locations defined by a simple function, the material will be "air" (e.g. void, or trans with pure specular transmission), everything else will be your wall material.
But: you likely introduce later problems when modeling that way. Once that you have overlaps of your invisible, but still existing wall polygon with other geometry (window pane, bsdf or illum, ..) you will get strang results which are hard to debug. I would not recommend this for a simple wall. There are cases where this may make sense, though - e.g. if you want to cut a hole into a sphere, you can either use antimatter or mixfunc into a sphere primitive with few lines of Radiance scene description, or you have to mesh the hole sphere object... possibly leading to a megabyte of triangles...
Dear All,
Is it possible to create a void in a wall instead of creating polygons around a void?
For instance:
for creating a window we can generate polygons surrounding the window and then a polygon which refers to glass. now I want to know instead of doing that is it possible to define a wall as a polygon and create a window on the wall without manipulating the wall's polygon.
Best Regards,
Ehsan
Thanks for your early respond Lars.
If I understand correctly to create a window within the wall I need to use
a mixfunc, because using antimatter will make everything invisible, right?
Cheers, Ehsan
On Wed, Jan 29, 2014 at 1:18 PM, Lars O. Grobe <[email protected]> wrote:
Hi Ehsan,
triangles...
> Dear All,
around a void?
> For instance:
> Best Regards,
> Ehsan
> [email protected]
E. M. Vazifeh
Project Assistant
Department of Building Physics and Building Ecology
Vienna University of Technology
Karlsplatz 13, A-1040 Vienna, Austria
Tel +43 1 58801 27003
Fax +43 1 58801 27093
www.bpi.tuwien.ac.at
If you use antimatter, you will need to create a box that cuts through the wall to make an opening, creating more geometry than simply making an opening in the wall in the first place.
Using mixfunc, you can alternate materials in the wall, but if the wall has thickness, you will end up seeing "into" the wall this way, unless you also insert some sill geometry. Again, it ends up being easier to create the opening for a thick wall.
Date: January 29, 2014 4:42:44 AM PST
If I understand correctly to create a window within the wall I need to use a mixfunc, because using antimatter will make everything invisible, right?
Cheers, Ehsan
Hi Ehsan,
> Dear All,
> For instance:
> Best Regards,
> Ehsan
> [email protected]
E. M. Vazifeh
Project Assistant
thank you,
finally, I ended up with creating an opening by generating surrounding
surfaces. a bit of more coding lines but simplest way :slight_smile:
Ehsan
*Date: *January 29, 2014 4:42:44 AM PST
Cheers, Ehsan
Hi Ehsan,
triangles...
> Dear All,
around a void?
> For instance:
> Best Regards,
> Ehsan
> [email protected]
E. M. Vazifeh
Project Assistant
E. M. Vazifeh
Project Assistant
