Could RTRACE produce two outputs (picture and values)?
Dear all,
Just a short question, unfortunately I wasn't able to find the answer on the Radiance-community:
Is it possible to create two outputs using RTRACE:
- a .hdr picture and
- a text file containing illuminance values.
In case of a virtual plane, rtrace has to be used instead of rpict (as explained in the Radiance Tutorial). Now, I'm doing the same simulation twice in order to get 2 outputs which takes a lot of time. Isn't it possible to create 2 outputs through only 1 simulation?
If not, could pvalue help me on this one? And if yes, how? Or would pvalue only would give me luminance values?
First simulation:
echo " Rtrace illuminance "
vwrays -x $Dims -y $Dims -vf viewfile.vf \
rcalc -e '$1=$1; $2=$2; $3=0.75; $4=$4; $5=$5; $6=1' \
rtrace -w -ab 3 -fac -I -ov `vwrays -d -vf viewfile.vf -x $Dims -y $Dims` scene.oct > Outcome.hdr
Second simulation:
echo " Rtrace illuminance values "
vwrays -x $Dimstable -y $Dimstable -vf viewfile.vf \
rcalc -e '$1=$1; $2=$2; $3=$3; $4=$4; $5=$5; $6=1' \
rtrace -w -I -h -ov -ab 2 `vwrays -d -vf viewfile.vf -x $Dims -y $Dims` scene.oct | rcalc -e '$1=$1*179' > Outcome.txt
Thanks in advance for your help!
Best regards,
Mirjam
If you add a parameter to both rtrace commands such as "-af simulation1.amb" it will save an ambient cache in your current working directory and make the second command run faster. You will want to be sure that your ambient calculation parameters are the same for both, in your case it looks like you're taking the rtrace defaults for both. If you revise your model or calculation parameters, you will also want to manually delete the ambient cache before you run again, because you will either see strange results or an error message if you inadvertently try to use the old cache for a new calculation.
