Dear all,
I have used Konica Minolta (CL-500A) spectrometer to measure X Y Z values
of the real sky using the data management software CL-S10w. I want to
convert these X Y Z values to the Radiance R G B. Is there any way/script
for such conversion?
Thanks in advance,
Kind regards,
Parisa
Hi Parisa,
You can use the xyz_rgb.cal definitions in ray/src/cal/cal, like so:
rcalc -f xyz_rgb.cal -e "$1=R($1,$2,$3);$2=G($1,$2,$3);$3=B($1,$2,$3)"
Then, type or redirect your XYZ values separated by spaces or tabs to the standard input to get RGB values on the standard output.
Subject: [Radiance-general] Converting XYZ to Radiance RGB
Date: June 23, 2016 8:34:54 AM EDT
Reply-To: Radiance general discussion <radiance-general@radiance-online.org>
Dear all,
I have used Konica Minolta (CL-500A) spectrometer to measure X Y Z values of the real sky using the data management software CL-S10w. I want to convert these X Y Z values to the Radiance R G B. Is there any way/script for such conversion?
Thanks in advance,
Kind regards,
Parisa
Thank you so much! I will give it a try.
Parisa
On 23 June 2016 at 15:12, Greg Ward <gregoryjward@gmail.com> wrote:
Hi Parisa,
*Subject: *[Radiance-general] Converting XYZ to Radiance RGB
*Date: *June 23, 2016 8:34:54 AM EDT
*To: *Radiance general discussion <radiance-general@radiance-online.org>
*Reply-To: *Radiance general discussion <
Dear all,
Thanks in advance,
Kind regards,
Parisa
Use single quotes if on bash...
On 6/23/16, 7:12 AM, "Greg Ward" <gregoryjward@gmail.com<mailto:gregoryjward@gmail.com>> wrote:
Hi Parisa,
From: parisa khademagha <p.khademagha@gmail.com<mailto:p.khademagha@gmail.com>>
To: Radiance general discussion <radiance-general@radiance-online.org<mailto:radiance-general@radiance-online.org>>
Reply-To: Radiance general discussion <radiance-general@radiance-online.org<mailto:radiance-general@radiance-online.org>>
Dear all,
Thanks in advance,
Kind regards,
Parisa
