Conversion of obj files
Hello Brian,
A quick check of http://www.fileformat.info/format/material provides some information on the file format which could be used as a guide.
Using your {mtl} file:
newmtl appearance0
Ka 0.793125 0.793125 0.793125
Kd 0.793125 0.793125 0.793125
Ks 0.119 0.119 0.119
Ns 119.04
d 1
illum 2
To list all materials in the mtl file listing all line containing the newmtl string:
     grep newmtl {mtl}
     In your case the first materials name is appearance0
     According to http://www.fileformat.info/format/material:
         The Ka statement specifies the ambient reflectivity using RGB values.
"r g b" are the values for the red, green, and blue components of the color. The g and b arguments are optional. If only r is specified, then g, and b are assumed to be equal to r. The r g b values are normally in the range of 0.0 to 1.0. Values outside this range increase or decrease the reflectivity accordingly.
         The Kd statement specifies the diffuse reflectivity using RGB values.
         The Ks statement specifies the specular reflectivity using RGB values.
Therefore a simple material definition for your appearance0 might be:
void plastic appearance0
0
5 0.793125 0.793125 0.793125 .1 .1
The last two parameters (.1 and .1) are the specularity and roughness. Specularity fractions greater than 0.1 and roughness values greater than 0.2 are not very realistic.
*Terrance McMinn
