computing the standard deviation of pixels above zero
Hi Kyle,
Between your toflt and total put the following:
... | toflt | rcalc -if -of -e '$1=$1;cond=1e-6-$1' | total -if ...
Date: June 14, 2010 2:58:11 PM PDT
I have an HDR image that was generated by combining the original HDR with
an equally sized bitmap image to mask out an area within the image for
analysis. I have a script that enables the average luminance of the masked
area to be computed via (from the below script):
taskavg=`thpic -o $inp $tdir/$task.pic | toflt | total -if`
*I would like to compute the standard deviation of only the non-zero
pixels and am unsure how to do this.
the program "total" has a number of options to calculate the mean, max,
min, RMS,etc, but i need to filter out all of the zero'ed pixels before/as
I pass the pixel data to it.
Any suggestions would be appreciated. I have put a sample image (out.hdr)
as well as the script, mask, and orig image (example.hdr) in the following
directory online
https://gaia.lbl.gov/people/kskonis/share/TEMP/masks_lab/
best,
Kyle Konis
KjhjgthGyWWWWWwwwWwweeeererrRRrrrrrrrrrrrTttttYYyyYuuiiooplkm¥fffffggggGGfGFgfgfGfGfgfffgfGtgFGGGGxudgfnmxfN
----- Original Message -----
Sent: Tue Jun 15 04:56:36 2010
Subject: Re: [Radiance-general] computing the standard deviation of pixels above zero
On Mon, Jun 14, 2010 at 10:58 PM, <[email protected]> wrote:
# -h -H do not print header or resolution string
# -pG print only the primary GREEN
# -df Output [binary 32-bit float values]
alias toflt 'pvalue -h -H -pG -df \!*'
You probably should add a "-o" option here, too, unless you always use
images fresh from rpict (no further pfilt treatment).
Ahh, seems Kristopher's kitty found a nice, warm laptop to sleep on...
Date: June 15, 2010 4:40:23 PM PDT
LOL!
From: [email protected] [[email protected]] On Behalf Of Greg Ward [[email protected]]
Sent: Tuesday, June 15, 2010 6:13 PM
