Components don't show up
Hi All
I'm doing a glare analysis using Radiance in IES Virtual Environments.
For some reason, the components in the room sometimes don't show up and
I get the following error:
0.00 %, oconv started processing 0.0000 hrs.
xform2: cannot find file
"\CHRIST~1\100501~1\MELBOU~1\Radiance\Laptop13.rad"
"\CHRIST~1\100501~1\MELBOU~1\Radiance\Screen16.rad"
"\CHRIST~1\100501~1\MELBOU~1\Radiance\PERPET~1.RAD"
"\CHRIST~1\100501~1\MELBOU~1\Radiance\PHONE1~1.RAD"
warning - (!xform2 -rz 90.000 -t 0.544 1.084 0.701
\CHRIST~1\100501~1\MELBOU~1\Radiance\Laptop13.rad): empty file
\CHRIST~1\100501~1\MELBOU~1\Radiance\Screen16.rad): empty file
warning - (!xform2 -t -0.469 0.492 0.021
\CHRIST~1\100501~1\MELBOU~1\Radiance\PERPET~1.RAD): empty file
warning - (!xform2 -rz 90.000 -t -0.023 0.839 0.053
\CHRIST~1\100501~1\MELBOU~1\Radiance\PHONE1~1.RAD): empty file
99.00 %, oconv finished after 0.0000 hrs.
This error came up after I changed the sky file, but it happened quite
randomly before, so I'm not sure whether this has anything to do with
it. Sometimes the same simulation worked fine when I ran it on a
different PC. However, the problem seems to spread.
Did this happen to anyone before? Can anyone point to what am I doing
wrong?
Greetings from Melbourne
Chris
Kind regards,
Christoph Begert
Associate
sbe
sustainable built environments
Innovative ideas, collaborative design, practical solutions
Melbourne
Level 2, 525 Flinders St
Melbourne Victoria 3000
Australia
T: +61 3 9923 2345
F: +61 3 9923 2346
E: [email protected]
W: www.sbe.com.au <http://www.sbe.com.au/>
Sydney
Level 6, 61 Market Street
Sydney NSW 2000
Australia
T: +61 2 8289 5720
F: +61 2 9286 3745
Perth Agent Encycle
Level 10, 200 St Georges Terrace
PO Box 7620
Cloisters Square
Perth WA 6000
Australia
T: +61 8 9321 8760
F: +61 8 9485 0575
SBE - Winners of:
National Australian Women in Construction - 2009
Winners of the Crystal Vision Award for advancing the interests of women
in the construction industry.
Winners of The Building Commission Award for outstanding achievement as
a business woman.
Royal Australian Institute of Architects (National) - 2007
Award for Sustainable Architecture University of Tasmania School of
Architecture in collaboration with Six Degrees.
Lachlan Macquarie Award for Heritage University of Tasmania School of
Royal Australian Institute of Architects (Tasmanian Chapter) - 2007
Sustainable Architecture, Heritage and Public Architecture For the
design of the School of Architecture at the University of Tasmania as
architects in collaboration with Six Degrees
The contents of this email and its attachments are confidential and
privileged. Any unauthorised use of the contents is expressly
prohibited. If you receive this email in error, please contact us, then
delete the email. Before opening or using attachments, check them for
viruses and defects. The contents of this email and its attachments may
become scrambled, truncated or altered in transmission. Please notify us
of any anomalies.
Hi Christoph!
I do not know that environment, however it seams that it simply calls rad on a scene?
Hm, it looks like you have a modified version of oconv, never seen the time output for it before. I also do not know xform2. However the message is clear - the files are not found. Either this is a mistake by xform2 or by the tool that was supposed to generate these files. So the first thing to do is to check whether the listed files are at the given locations. I guess the weird directory name have to do with some windows file-system limitations? What surprises me is that xform2 uses backslashes for directories - is this the modification against xform that led to the name change?
If it happened randomly before there seam to be other reasons.
So as mentioned before, it seams that the commands involved are not really part of radiance but some derived, modified binaries. Start debugging by finding out whether the error messages correctly detect these missing files. Then one could start to find out how this IES Virtual Environment works and creates / names / writes the files. In radiance, one would also typically have a variable RAYPATH set including all file system paths where scene files are to be found.
Cheers
Lars.
Chris,
Xform2 is an additional program that IES created. Similar to xform, IES uses xform2 to create rectangles of arbitrary dimension for, it seems, use as workplanes (and perhaps other functions). It does this by applying arbitrary scaling in the x and y dimensions (independently) on a unit square polygon (z = 0.8) and translating the output to the desired location in the scene. In addition to the usual xform options, xform2 has -sx and -sy to perform the scaling in the x & y dims.
I came across this IES peculiarity when transferring IES created geometry to other platforms for simulation using standard (UNIX) Radiance. In those instances it was simply a matter of stripping out the xform2 commands, which didn't affect the building geometry since their use was confined to generating workplanes. However, from the error messages that you posted it seems that xform2 is being used for more general transformations where xform would suffice. Perhaps IES have replaced xform with their own xform2. As an aside, I'm surprised to see any form of xform/2 command used for general building geometry created in IES because I expected its 3D modeller to create explicit geometry (for all but the workplanes).
-John
Dr. John Mardaljevic
Reader in Daylight Modelling
De Montfort University
The Gateway
Leicester
LE1 9BH, UK
+44 (0) 116 257 7972
+44 (0) 116 257 7981 (fax)
http://www.iesd.dmu.ac.uk/~jm
Thanks John and Lars
I tried a few things based on your comments, e.g. calling up xform
instead of xform2, making sure that the location input is ok, but
unfortunately without success.
The problem really seems to be specific to certain computers. One file
which ran fine yesterday on my colleagues computer, didn't work on mine
when I tried to run it just afterwards.
Could it be that there is something in e.g. my windows registry that
causes this issue? The batch files created by VE include the following
line before they run the radiance programs:
SET PATH=C:\Windows;C:\Windows\system32;C:\Program Files\IES\VE
6\apps\ray
Cheers
Chris
Kind regards,
Christoph Begert
Associate
sbe
[mailto:[email protected]] On Behalf Of John
Mardaljevic
Sent: Monday, 10 May 2010 7:59 PM
Subject: [Radiance-general] Components don't show up
Chris,
& y dims.
-John
The Gateway
Leicester
LE1 9BH, UK
[mailto:[email protected]] On Behalf Of Lars
O. Grobe
Sent: Monday, 10 May 2010 11:21 AM
Subject: Re: [Radiance-general] Components don't show up
Hi Christoph!
rad on a scene?
and
Cheers
Lars.
All I can recall from memory is that IES didn't like spaces in file names at one point in its history.
Sent from my iPhone
On 11 May 2010, at 07:14, "Christoph Begert - SBE" <[email protected] > wrote:
6\apps\ray
Cheers
Chris
Kind regards,
Christoph Begert
Associate
sbe
Mardaljevic
Chris,
& y dims.
-John
The Gateway
Leicester
LE1 9BH, UK
O. Grobe
Hi Christoph!
rad on a scene?
and
Cheers
Lars.
Another peculiarity of IES, at least the Radiance part, is that it doesn't like to work from anything other than the system disk, i.e. trying to work from a project saved on USB stick/drive nearly always leads to problems (I imagine it's the same for FW drives). You're advised to save a project as a CAB file and copy that if you want to transfer a project between computers. Probably best to ensure also that the various PCs are running the same version of IES.
-John
The Gateway
Leicester
LE1 9BH, UK
