Dear all,
I am trying to compile the source code of accelerad in a CentOS linux system with the instructions below:
git clone https://github.com/nljones/Accelerad.git
mkdir AcceleradBuild
cd AcceleradBuild
cmake …/Accelerad
make
But it looks like Cmake on CentOS is not recognizing the cv command, which is a Radiance command.
When I type make, I do not produce all the executables I need and the output is:
[ 1%] Built target libreetz
[ 2%] Built target mgf
[ 3%] Built target rgl
[ 19%] Built target rtrad
[ 29%] Built target radiance
[ 29%] Built target testBSDF
[ 29%] Built target cnt
[ 29%] Built target ev
[ 29%] Built target histo
[ 29%] Built target icalc
[ 29%] Built target neaten
[ 30%] Built target rcalc
[ 30%] Built target rlam
[ 30%] Built target tabfunc
[ 30%] Built target total
[ 30%] Built target 3ds2mgf
[ 30%] Built target arch2rad
[ 30%] Built target bsdf2klems
[ 31%] Built target bsdf2rad
[ 31%] Built target bsdf2ttree
[ 32%] Built target bsdfquery
[ 33%] Built target epw2wea
[ 34%] Built target ies2rad
[ 35%] Built target lampcolor
[ 35%] Built target mgf2inv
[ 36%] Built target meta
[ 36%] Built target mgf2meta
[ 36%] Built target mgf2rad
[ 37%] Built target mgfilt
[ 38%] Built target nff2rad
[ 39%] Built target obj2rad
[ 39%] Built target pkgBSDF
[ 40%] Built target rad2mgf
[ 41%] Built target tmesh2rad
[ 42%] Built target genbeads
[ 42%] Built target genblinds
[ 42%] Built target genbox
[ 42%] Built target genbranch
[ 42%] Built target gencatenary
[ 43%] Built target genclock
[ 43%] Built target gendaylit
[ 43%] Built target gendaymtx
[ 43%] Built target genmarble
[ 44%] Built target genprism
[ 44%] Built target genrev
[ 44%] Built target gensky
[ 45%] Built target gensurf
[ 45%] Built target genworm
[ 45%] Built target raycalls
[ 45%] Built target mkillum
[ 45%] Built target mksource
[ 45%] Built target replmarks
[ 45%] Built target xform
[ 45%] Built target genrhgrid
[ 46%] Built target rhcopy
[ 46%] Built target rhinfo
[ 48%] Built target rholo
[ 49%] Built target rhoptimize
[ 50%] Built target rhpict
[ 51%] Built target x11.hdi
[ 52%] Built target bgraph
[ 53%] Built target cv
[ 53%] Built target dgraph
[ 53%] Built target gcomp
[ 53%] Built target igraph
[ 54%] Built target meta2bmp
[ 55%] Built target meta2tga
CMake Error: cmake version 3.1.1
Usage: /user/other/abinitio/bin/cp2k-5.1_no_inf_mkl_leaf/tools/toolchain/install/cmake-3.1.1/bin/cmake -E [command] [arguments …]
Available commands:
chdir dir cmd [args]… - run command in a given directory
compare_files file1 file2 - check if file1 is same as file2
copy file destination - copy file to destination (either file or directory)
copy_directory source destination - copy directory ‘source’ content to directory ‘destination’
copy_if_different in-file out-file - copy file if input has changed
echo [string]… - displays arguments as text
echo_append [string]… - displays arguments as text but no new line
env [–unset=NAME]… [NAME=VALUE]… COMMAND [ARG]…
- run command in a modified environment
environment - display the current environment
make_directory dir - create a directory
md5sum file1 […] - compute md5sum of files
remove [-f] file1 file2 … - remove the file(s), use -f to force it
remove_directory dir - remove a directory and its contents
rename oldname newname - rename a file or directory (on one volume)
tar [cxt][vfz][cvfj] file.tar [file/dir1 file/dir2 …]
- create or extract a tar or zip archive
sleep <number>… - sleep for given number of seconds
time command [args] … - run command and return elapsed time
touch file - touch a file.
touch_nocreate file - touch a file but do not create it.
Available on UNIX only:
create_symlink old new - create a symbolic link new -> old
src/meta/CMakeFiles/mta.dir/build.make:49: recipe for target ‘src/meta/CMakeFiles/mta’ failed
make[2]: * [src/meta/CMakeFiles/mta] Error 1
CMakeFiles/Makefile2:3484: recipe for target ‘src/meta/CMakeFiles/mta.dir/all’ failed
make[1]: * [src/meta/CMakeFiles/mta.dir/all] Error 2
Makefile:147: recipe for target ‘all’ failed
make: * [all] Error 2
Any ideas of I could fix it?
Thank you !
