CFS with Radiance
Hi G. Larrain,
Thanks for your detailed clarification (below).
I wonder if you kindly can help me toward better understanding and answering the following:
We agreed that for daylight modelling of spaces with CFS, Radiance is a suitable tool as it applies ray-tracing method. And for annual and/or climate-based daylight calculations, as calculation time becomes a critical factor, using BSDF data for CFS is highly recommended to tackle the task with radiance (using phases methods). However:
- if someone needs to perform daylight calculations for given space with different CFS (different cases for comparison purposes) to get illumination levels for horizontal grid points (and not pictures nor scenes), is Radiance still the most convenient option?
- is it still needed to use any of the phase methods (2, 3 or 5)?
- most importantly, is it still needed to get BSDF data for CFS or just can model the detailed CFS in Radiance (and, if yes, how?)
Many thanks for your kind help :slight_smile:
Regards
Ikrima
"Ikrima,
I am going to try to build the puzzle of CFS, Phases, BSDF and calculations.... at least the way I understand it.
*CFS* are those systems that, via interreflection or other light transport phenomena, redirect light (or solar radiation). Thus, in order to get a reliable result you will have to consider all the phenomena involved.
Then, *common
simple performance indexes*, such as the miss-used Shading Coefficient and the Aperture Percentage, *always loose a lot of information, trying to reduce all the complex behavior of a CFS to one single number*. We all know that venetian blinds are more "transparent" from certain viewing directions than from others, but these performance indexes do not tell you that.
Now... Radiance can certainly perform calculations of spaces with CFS using its "common" Ray-tracing. However, this may be slow for some purposes (i.e.
annual simulations and climate-based daylight modelling), and *this is why 2, 3 and 5 phase methods have been developed*. The *BSDF* representation, I would say, goes in the same direction... It allow summarizing all the bounces, reflections, refractions, etc. that occure withing the CFS in a single matrix or tensor.* By using BSDFs*, Radiance itself and other tools (i.e. EnergyPlus) can treat CFS as blackboxes, avoiding all the opcits within the system. A BSDF that uses the Klems Full representation has
21,045 numbers (instead of one, such as the Shading Coefficient).
Being said all that, I would not trust a calculation method unless it can actually deal with the optics of a CFS that is drawn and/or it can use BSDF (or similar) information.
Lets remember that a perforated screen, a venetian blind, a light diffusing device can all have a Shading Coefficient of 50%, but all of them will behave very differently. I made some presentations about this on my previous work (we sold complex Shading Devices), trying to promote the use of BSDF in EnergyPlus calculations... the differences (in solar heat gains) were more than considerable.
I hope that someone else gives us his/her perspective on this topic...
there are a lot of concepts that I might be misunderstanding.
Best!"
This message and any attachment are intended solely for the addressee
and may contain confidential information. If you have received this
message in error, please send it back to me, and immediately delete it.
Please do not use, copy or disclose the information contained in this
message or in any attachment. Any views or opinions expressed by the
author of this email do not necessarily reflect the views of the
University of Nottingham.
This message has been checked for viruses but the contents of an
attachment may still contain software viruses which could damage your
computer system, you are advised to perform your own checks. Email
communications with the University of Nottingham may be monitored as
permitted by UK legislation.
Some very quick replies and clarifications within:
Hi G. Larrain,
BSDF data in an annual simulation context is generally limited to Klems
basis BSDF data, which may not be high enough resolution for some CFS. And
the 5-phase method, which can circumvent this, is not necessarily "quick".
This is all still very much a quandary and the newest daylight metrics
have added confusion to all of this, IMO.
Absolutely. The lack of an image-as-output requirement does not change the
fact that ray tracing is a good/convenient algorithm option for daylight
simulation problems, especially when dealing with diffusing media and CFS
in general. BSDFs allow you to do lots of "what-ifs", relatively quickly,
but are beholden to the limitations of the resolution of the BSDF.
Is what still needed? BSDF data? Ray tracing? I don't know of other
lighting simulation tools that can employ the multiphase methods. I would
say BSDF data is optional for 2-phase, required for 3-phase, and optional
for 5-phase.
Again I'm confused as to what "it" is. A couple of approaches are
available to you in general. If you have a geometric model of the CFS you
can use Radiance (genBSDF) to make a BSDF of the CFS and use that in a 3-
or 5-phase context. However in an annual/climate-based simulation context,
you will be stuck with a Klems basis BSDF and that will not be very good
resolution for a lot of CFS; here you may want to use the 5-phase method
and stick the actual CFS geometry in the building model.
Some things to consider here are the photon map, now a part of Radiance
proper, or using the 2-phase method where appropriate. By 2-phase method I
mean generating a daylight matrix for your calculation points (or view),
and modeling the window material as-is. If the "CFS" is a shade cloth, you
can approximate that with a Radiance "trans". Same for translucent panels.
With this single daylight matrix, you can throw a vector of sky matrices
at it and get an annual climate-based result very quickly. Problem is, we
want to do stuff to the windows, sometimes at the time step level, so:
Blinds and compact daylight redirection devices (e.g. Lightlouver) are
best represented as BSDF, and if most of the redirected flux is headed up
and away from the points of interest, a Klems basis BSDF is good enough
IMO. In these cases you could use the 3-phase method. Problem is when you
have a BSDF for blinds, and you also want to simulate the blinds-up
condition (i.e. clear, specularly transmitting glass). Using a Klems basis
BSDF for this is sub-optimal. You end up needing to do two annual
simulations, one as 2-phase for the clear glass scenario, and again as a
3-phase (with a blinds BSDF for the transmission matrix) for the blinds
down condition. If you have a lot of different window groups, your
simulation space can get large in a hurry. But it's still do-able and you
can get results that tell a story you simply couldn't tell 5 years ago,
informing the newest daylight metrics as well.
On 7/9/15, 10:26 AM, "Ikrima Amaireh" <[email protected]> wrote:
I must say that I agree with Rob, however, a short answer that might help.
For evaluating illuminance levels in a space with different CFS you,
strictly speaking, DO NOT HAVE TO do anything. You may choose between
different methods that have some pros and cons.
*ray-tracing*
   - Requires ray-tracing for each time-step and each system, which is slow
   (*four systems simulated annualy in an hourly basis --> 4*8760 = 35,040
   simulations*.)
   - As accurate as it gets, if options are defined correctly.
*2 phase method*
   - Do not need the BSDF
   - Requires ray-tracing for each CFS (*4 systems --> 4 ray-tracing
   simulations*)
   - After ray-tracing, annual simulation is fast.
*3-phase method:*
   - Requires BSDF data in KLEMS basis, which may be slow to compute,
   unless it can be exported from WINDOW, for example, or such data has
   already been calculated (the idea is to make a database, I think).
   - Does not really work well for specular systems (Klems patches are too
   big)
   - Requires 2 ray-tracing runs, always (*4 systems --> 2 ray-tracing
   simulations*)
   - After ray-tracing and BSDF calculation, annual simulation is fast
*5-phase method:*
   - Requires BSDF data in KLEMS basis AND/OR Tensor tree format, which
   may be slow to compute, unless it can be exported from WINDOW, for example,
   or such data has already been calculated (the idea is to make a database, I
   think).
   - Works well for specular systems
   - Requires 4 ray-tracing runs + 1 for each system, always (*4 systems
   --> 4+1 = 5 ray-tracing simulations*)
   - Hard to code...?
I would not say there is a recipe. If you have to choose between 1 or 2
CFSs, maybe it is faster to just draw them and use the 2 phase method (or
ray-tracing if an annual simulaton is not required). On the contrary, if
you are going to test 10 different CFSs, 3 and 5 phases may make sense,
since you reduce the expensive ray-tracing calculations... However, this
will also depend on weather you have the BSDF data AND/OR if it makes sense
to calculate it and store it AND/OR if you intend to simulate a dynamically
controlled CFS.
Best!
2015-07-09 14:29 GMT-03:00 Guglielmetti, Robert < [email protected]>:
>Hi G. Larrain,
for 5-phase.
