Can this be done with pcomb?
Hello All,
I have a pic file of an indoor scene with windows that I want to test
with varying visible transmittance of the glass. Without having to run
rpict again, is there a way of dropping down the sky luminance using a
multiplier OR to uniformly drop down the light in the scene by combining
the pic (using pcomb) with pic file of a screen of a specific
transmittance? In other words, can I just filter down the light levels
uniformly in the scene without having to run rpict again.
Thanks.
Autif
The short answer is 'yes.' Light is linear, so you can always scale according to window transmittance for light coming through the window. There may be some (very) slight inaccuracies due to the varying angular transmittance, but the results should be roughly correct.
If the window is the only source of light in the room, and you are adjusting the picture exposure rather than looking at the luminance/radiance values, then you will see no change at all, because one will compensate for the other.
Date: June 10, 2010 9:23:36 AM PDT
Hello All,
I have a pic file of an indoor scene with windows that I want to test with varying visible transmittance of the glass. Without having to run rpict again, is there a way of dropping down the sky luminance using a multiplier OR to uniformly drop down the light in the scene by combining the pic (using pcomb) with pic file of a screen of a specific transmittance? In other words, can I just filter down the light levels uniformly in the scene without having to run rpict again.
Thanks.
Autif
Thanks Greg,
Window is the only source of light in the room. I do want to get the
luminance values from the modified pic file, so it seems adjusting
exposure will not be the right approach. I was thinking pcomb could be
used for this, but have not been able to figure out how to do it yet.
Any suggestions or guidance would be great..
Autif
[mailto:radiance-general-bounces@radiance-online.org] On Behalf Of Greg
Ward
Sent: Thursday, June 10, 2010 11:42 AM
Subject: Re: [Radiance-general] Can this be done with pcomb?
Hello All,
Thanks.
Autif
The command is:
  pcomb -s scaling -o orig.hdr > scaled.hdr
Date: June 10, 2010 9:50:48 AM PDT
Thanks Greg,
Autif
