calculating transmissivity
Project Code : .
I am having trouble calculating the correct transmissity values to use
within Radiance.
The transmittance values i need to calculate from are 0.46 and 0.70. Can
someone please tell me what the corresponding transmissivity values will
be?
I am trying to use a formula from the Rayfront website, but I am getting
some strange results...
Ben Masters
___________________________________________________________________________________________________
A person using Connell Wagner drawings and other data accepts the risk of :
* Using the drawings and other data in electronic form without requesting
and checking them for accuracy against the original hard copy version ;
* Using the drawings or other data for any purpose not agreed to in
writing by Connell Wagner. (ABN 54 005 139 873)
This e-mail message and any attached files may hold confidential
information. If you are not the intended recipient any use, disclosure or
copying of this e-mail is unauthorised. If you have received this e-mail in
error please notify the sender immediately by reply e-mail.
within Radiance.
be?
I'm assuming here that you're talking about the glass primitive.
The formula in ray.pdf is formatted in a slightly confusing way.
There's an unambiguous graphic version to be found here:
http://www.schorsch.com/rayfront/manual/dielectricdef.html#glass
-schorsch
Project Code : .
within Radiance.
be?
There is a .cal file in the UNIX distribution (in /src/cal/cal) of Radiance that you can use with the calc utility to easily compute these values. You type "calc /path/to/trans.cal" at the comand line, and feed it your transmission values (tn), and it spits out a transmissivity value:
% calc trans.cal (or full pathname if not in a PATH location)
tn(.88)
$1=0.958415435
tn(.57)
$2=0.621392084
Just keep on feedin' it values and recording the output, and hit control+D to quit when you're done.
      Rob Guglielmetti
e. rpg@rumblestrip.org
w. www.rumblestrip.org
