BSDFViewer - installation
Dear mailing list (most probably Andy McNeil),
sorry for the _yet another installation proble__m_:
I am not able to install the BSDFViewer (looked through all of the already given answers in the archives - without much progress).
All works well until:
/usr/bin/ld: badarg.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
badarg.o: error adding symbols: Bad value
collect2: error: ld returned 1 exit status
In file included from libBSDF.h:2:0,
                  from libBSDF.cpp:13:
/usr/lib/jvm/java-8-openjdk-amd64/include/jni.h:45:20: fatal error: jni_md.h: No such file or directory
compilation terminated.
g++: error: libBSDF.o: No such file or directory
g++: error: libBSDF.so: No such file or directory
g++: fatal error: no input files
cp: cannot stat 'BSDFViewer/libBSDF.so': No such file or directory
I did install the /java development environment/, well but further, I am not able to move.
Thanks for any hints, and kind regards,
Paulína
Paulína Šujanová
PhD student
Department of Building Construction
Faculty of Civil Engineering
Slovak University of Technology in Bratislava
Dear all,
in the meantime, I was able to get to just one error:
g++: error: libbsdf.so: No such file or directory
But I really am not anymore able to solve this. So please, please help.
Kind regards,
Paulína
On Tue, 25 Oct 2016 00:02:48 +0200 Paulína Šujanová <[email protected]> wrote:
able to move.
Paulína
Paulína Šujanová
PhD student
Hi Paulina,
First, libBSDF is only needed for tensor tree BSDFs. If you only need to
view klems BSDFs let me know and I can send you a version that doesn't
support tensortree and will save all this extra hassle.
Did you try adding the -fPIC flag to the g++ command for compiling the
library? I've added and removed this flag a few times. It seems that some
systems need it while other systems can't have it. I'm not a linux expert
so I'm not sure why the difference, or how to spot the difference.
Have you tried running as root?
sudo bash /install.sh
You'll might root permission to put the shared object in the /usr/lib
(though I wouldn't expect it to be necessary).
Can you check to see if /usr/lib even exists on your system? And that it
contains libBSDF.so?
Andy
On Tue, Oct 25, 2016 at 4:06 AM, Paulina Sujanova <[email protected]> wrote:
Dear all,
Kind regards,
Paulína
On Tue, 25 Oct 2016 00:02:48 +0200 > Paulína Šujanová <[email protected]> wrote:
can not
jni_md.h:
not
>able to move.
>Paulína
>Paulína Šujanová
>PhD student
i remember that i had problems with this in the past too. I got it working
in the end, but i cannot remember what was the key... here is my modified
version of the install.sh file. Hope this can help.
While i m there, @ Andy, For the tensor tree visualization, is it normal
that you don't get the percent value for the outgoing patch when clicking
it (as you get for the Klems representation)
André
cd BSDFViewer
make -f Rmakefile clean
make -f Rmakefile all
g++ -shared -fPIC -o libBSDF.so addobjnotify.o badarg.o biggerlib.o
bmalloc.o \
bmpfile.o bsdf.o bsdf_m.o bsdf_t.o byteswap.o caldefn.o calexpr.o calfunc.o
calprnt.o ccolor.o ccyrgb.o chanvalue.o clip.o color.o colrops.o dircode.o \
disk2square.o ealloc.o eputs.o error.o expandarg.o ezxml.o falsecolor.o \
fdate.o fgetline.o fgetval.o fgetword.o font.o fputword.o fropen.o fvect.o \
gethomedir.o getlibpath.o getpath.o header.o hilbert.o invmat4.o \
lamps.o linregr.o loadbsdf.o lookup.o mat4.o mgf_context.o mgf_object.o \
mgf_parser.o mgf_xf.o multisamp.o myhostname.o objset.o octree.o \
paths.o plocate.o portio.o process.o quit.o readfargs.o resolu.o rexpr.o \
savestr.o savqstr.o spec_rgb.o tcos.o tmap16bit.o tmapcolrs.o tmesh.o
tonemap.o \
unix_process.o urand.o urind.o wordfile.o words.o wputs.o xf.o zeroes.o
javac libBSDF.java
javah -o libBSDF.h libBSDF
JAVA_HOME=$(readlink -f /usr/bin/javac | sed "s:/bin/javac::")
g++ -shared -fPIC -I$JAVA_HOME/include \
    -o libBSDF.o -c libBSDF.cpp
g++ -shared -I$JAVA_HOME/include \
    -o libBSDF.jnilib libBSDF.o libBSDF.so
On Tue, Oct 25, 2016 at 9:00 PM, < [email protected]> wrote:
Today's Topics:
   1. BSDFViewer - installation (Paul?na ?ujanov?)
   2. Re: BSDFViewer - installation/update (Paulina Sujanova)
   3. Re: BSDFViewer - installation/update (Andy McNeil)
Message: 1
Date: Tue, 25 Oct 2016 00:02:48 +0200
Subject: [Radiance-general] BSDFViewer - installation
Content-Type: text/plain; charset="utf-8"; Format="flowed"
not able to move.
Paul?na
Paul?na ?ujanov?
PhD student
URL: <http://www.radiance-online.org/pipermail/radiance-
general/attachments/20161025/185ed746/attachment-0001.html>
Message: 2
Date: Tue, 25 Oct 2016 13:06:07 +0200
To: <[email protected]>
Subject: Re: [Radiance-general] BSDFViewer - installation/update
Content-Type: text/plain;charset=utf-8
Dear all,
Kind regards,
Paul?na
On Tue, 25 Oct 2016 00:02:48 +0200 > Paul?na ?ujanov? <[email protected]> wrote:
can not
jni_md.h:
not
>able to move.
>Paul?na
>Paul?na ?ujanov?
>PhD student
Message: 3
Date: Tue, 25 Oct 2016 09:21:42 -0700
Message-ID:
        <CAEFJVk9aupf8_B9jJ6d8goK1X7DRmoKWNZnggzVngOc
[email protected]>
Hi Paulina,
Andy
On Tue, Oct 25, 2016 at 4:06 AM, Paulina Sujanova <[email protected]> > wrote:
> Dear all,
> Kind regards,
> Paul?na
> On Tue, 25 Oct 2016 00:02:48 +0200 > > Paul?na ?ujanov? <[email protected]> wrote:
already
> can not
> jni_md.h:
> not
> >able to move.
> >Paul?na
> >Paul?na ?ujanov?
> >PhD student
> [email protected]
general/attachments/20161025/430fdcf2/attachment-0001.html>
Subject: Digest Footer
End of Radiance-general Digest, Vol 152, Issue 12
Yes, this is normal. The falsecolor scale for tensor tree isn't percent of
incident light but instead the raw BSDF value. When the patches are all
different sizes you might have a large patch with relatively low intensity
that would have a large portion of the outgoing flux because of it's size.
Using raw BSDF value was the simplest way that I could come up with to
render the tensor tree BSDF. The raw BSDF value is kinda meaningless, so I
decided not to display anything.
Andy
On Wed, Oct 26, 2016 at 2:07 AM, Andre K <[email protected]> wrote:
André
cd BSDFViewer
bmalloc.o \
calfunc.o \
tonemap.o \
javac libBSDF.java
On Tue, Oct 25, 2016 at 9:00 PM, <radiance-general-request@ > radiance-online.org> wrote:
Today's Topics:
Message: 1
not able to move.
Paul?na
Paul?na ?ujanov?
PhD student
URL: <http://www.radiance-online.org/pipermail/radiance-general/
Message: 2
Dear all,
Kind regards,
Paul?na
On Tue, 25 Oct 2016 00:02:48 +0200 >> Paul?na ?ujanov? <[email protected]> wrote:
already
can not
jni_md.h:
not
>able to move.
>Paul?na
>Paul?na ?ujanov?
>PhD student
Message: 3
Message-ID:
        <CAEFJVk9aupf8_B9jJ6d8goK1X7DRmoKWNZnggzVngOcE9PQZjw@mail.
gmail.com>
Hi Paulina,
Andy
On Tue, Oct 25, 2016 at 4:06 AM, Paulina Sujanova <[email protected]> >> wrote:
> Dear all,
> Kind regards,
> Paul?na
> On Tue, 25 Oct 2016 00:02:48 +0200 >> > Paul?na ?ujanov? <[email protected]> wrote:
already
> can not
> jni_md.h:
am
> not
> >able to move.
> >Paul?na
> >Paul?na ?ujanov?
> >PhD student
> [email protected]
