behavior of 3ds2mgf
Hello all,
I have two 64bit machines here running und Gentoo Linux. When compiling the latest HEAD everything works just fine, all executables are built.
After running a few tests I discovered, that 3ds2mgf seems to be broken. This is the content of rmake:
#!/bin/sh
exec make "SPECIAL=" \
        "OPT=-O2" \
        "MACH=-Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO" \
        ARCH=IBMPC "COMPAT=erf.o" \
        INSTDIR=/opt/ray/bin \
        LIBDIR=/opt/ray/lib \
        ESUFFIX= \
        CC=gcc "$@" -f Rmakefile
"3ds2mgf file.3ds" only produces "file.mgf" with this content:
c R =
        cxy 0.640 0.330
c G =
        cxy 0.290 0.600
c B =
        cxy 0.150 0.060
i file.inc
and "file.inc" is empty. Can anyone reproduce this or maybe even better has a hint as to where I can start debugging this problem?
It seems all 32bit versions (older compiles) run fine on the same systems, i.e. they produce the expected output.
Thanks in advance,
Erwin
Hi Erwin,
I'm pretty sure the problem is in 3ds2mgf.c:
float read_float()
     dword data;
     data = read_dword();
     return *(float *)&data;
which assumes that "unsigned long" is 4-bytes long. This bit of code would actually work on a BigEndian system (I think), but not on Intel. This is not my code, so I'm not 100% confident on this fix, but try it:
float read_float()
     union { dword i; char c[8]; } u;
     dword data;
     if (sizeof(dword) == sizeof(float))
     u.i = 1;
     if (u.c[0] == 0)
         return *(float *)&data; /* assume big-endian */
     if (sizeof(dword) != 2*sizeof(float)) {
         fputs("Unsupported word length\n", stderr);
         exit(1);
     u.i = data;
     return *(float *)&u.c[4];
Sorry, Erwin. I tried. It isn't easy for me to debug something using a compiler I don't have on a machine I don't have.
Date: October 7, 2008 9:56:34 PM PDT
I have tried your patch but it didn't change things really. Out of curiosity I compiled the current head on a 32bit machine (also under Linux) and I get the exact same behavior (using the original 3ds2mgf.c).
So I finally tried an older binary of 3ds2mgf (Radiance 3.6a) on the same system and this one works just fine. Unfortunatly I dont have the sources anymore to see what happens if I compile them
Somehow I get a feeling it might have to do with the gcc version I am using on all these systems nowadays:
# gcc --version
gcc (GCC) 4.1.2 (Gentoo 4.1.2 p1.1)
For all older compilations I am pretty sure I was still using gcc 3.*.
Just in case that helps.
Erwin
Dont worry, I will figure it out eventually :wink:
Erwin
-------- Original Message --------
Subject: [Radiance-dev] Re: behavior of 3ds2mgf (08-Okt-2008 8:18)
> From: "Erwin Zierler" <[email protected]>
> 3ds2mgf.c).
> # gcc --version
> Erwin
Radiance-dev mailing list
Dear Erwin,
I don't know if the gcc is really the problem - but if yes, see below an
instruction how to build an older gcc version with a newer one. I use
that for compiling esp-r- which also has trouble with gcc4.xx.
Then you have two gcc versions in parallel. Be careful while installing:
you have to use the /make bootstrap /otherwise you can destroy your
system (if you install it as root it replaces the existing libraries -
I once destroyed my system with that....)
Before using programs compiled under gcc3.x, you have to set the library
path to the related lib-path ( export LD_LIBRARYPATH=/opt/gcc33/lib or
similar).
Good luck!
Jan
------------- Instruction to build an gcc 3.3.6, using gcc4.xx
Get gcc-core from from GCC Mirrors Page
Compiling GCC-3.3.6:
Untar the source then configure with:
./configure --prefix=/opt/gcc33 --program-suffix=-3.3
WARNING: Do NOT configure it with the default prefix! It is recommended
to compile it with this prefix else you can damage your system!
Now compile it with make bootstrap and after that install it with make
install.
# gcc --version
Erwin
Dipl.-Ing. Jan Wienold
Project Manager
Fraunhofer-Institut für Solare Energiesysteme
Thermal Systems and Buildings, Lighting and Daylighting
Phone: +49(0)761 4588 5133 Fax:+49(0)761 4588 9133
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
