Bad call to SDqueryTreProjSA for BSDF
Dear all,
I am getting the above error when rendering an image with rpiece/rpict on many cpu cores. The ambient cache is used (e.g. no -aa 0). Is it possible that this is due to multiple processes interfering (I am running 38 in parallel…)? Or is the BSDF the primary suspect in this case?
I updated to the latest head release as of today, but the error just occured again.
Right now I am trying out with fewer (18) processes, but this will obviously take some time befor I can confirm any effect.
Lars.
This was a bug that is rarely encountered, and has been fixed in the HEAD release with Lars' help.
Subject: Re: [Radiance-general] Bad call to SDqueryTreProjSA for BSDF
Date: November 19, 2017 1:43:14 PM PST
Dear Greg,
thank you, this has solved the issue!
17.11.17 at 16:53 Greg Ward wrote:
Hi Lars,
I had a look at the code, and realized there is a case where a BSDF that is zero in a neighborhood could generate this error. Try the attached version of src/rt/m_bsdf.c and tell me if it gets rid of your error. The number of processes shouldn't be a factor.
Date: November 17, 2017 5:26:07 AM PST
Dear all,
I am getting the above error when rendering an image with rpiece/rpict on many cpu cores. The ambient cache is used (e.g. no -aa 0). Is it possible that this is due to multiple processes interfering (I am running 38 in parallel...)? Or is the BSDF the primary suspect in this case?
Lars.
