Artificial lighting_lumen output multiplier in a continuing loop
Hello everyone,
I have a question regarding the luminaire output multiplier and I would really appreciate your help.
I am doing an experiment in a testbed, however, the inside natural lighting is very low, because of the sorrounding neightbouring walls so we decided to use an artificial uniform light (160x 160 cm) in the window as the light source, -looking at the values for different blind positions and based on a controller, some decisions are made regarding the blind position and the lighting inside the space.
My question is how to continuously change the lumen multiplier output (-m) , so without entering the -m value every time manually. I am an researcher in architecture, and I do not have good knowledge in programming.
ies2rad -dm -t default -m 1.0 TPH710_8xTL5-28W_827_865_HFR.ies
xform -rx 90 -t 4.52 -0.05 1.455 TPH710_8xTL5-28W_827_865_HFR.rad > artificial light.rad
and here is my script
            "oconv env.rad lab_surfaces_corrected_moved.rad lab_windows_and_doors.rad artificial light.rad> lab.oct", # gendaylit.rad is generated by this script
            "echo '4.52 0.85 0.74 0 0 1 " +
        "3.74 1.13 0.74 0 0 1 " +
        "4.52 1.13 0.74 0 0 1 " +
        "5.30 1.13 0.74 0 0 1 " +
        "3.74 2.13 0.74 0 0 1 " +
        "4.52 2.13 0.74 0 0 1 " +
        "5.30 2.13 0.74 0 0 1 " +
        "3.74 3.13 0.74 0 0 1 " +
        "4.52 3.13 0.74 0 0 1 " +
        "5.30 3.13 0.74 0 0 1 " +
            "' | rtrace -w -af /tmp/bpi.amb -as 512 -ar 64 -aa 0.15 -ab 3 -I+ -h lab.oct | rcalc -e '$1=($1*0.265+$2*0.670+$3*0.065)*179'"
Thank you very much,
Best regards,
Sokol Dervishi
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Hello everyone,
I assume you had your reasons but I'd have used something like a
glow rectangle to create a non-specific light source.
You can pack these two lines in a script an surround them with a "for ..." loop:
#!!WARNING: untested bash script with gaps to fill!!
for MF in 1.0 0.9 0.8 0.7 0.6 0.5 0.5 0.4 4 0.3 0.2 0.1
do
     ies2rad -dm -t default -m ${MF} TPH...HFR.ies
     xform -rx 90 -t 4.52 -0.05 1.455 TPH...HFR.rad > artificial_light.rad
     rm -f lab.oct # delete old octree if it exists
     oconv env.rad ... > lab.oct
     rm -f /tmp/bpi.amb # delete old ambient file if it exists
     echo my_data_points.dat | rtrace ... | rcalc -e ... > results_${MF}.out
done
Loose the spaces in the file names! The shell will see "artificial" and "light.rad"
as two file names to search for. Use "artificial_light.rad" instead.
Suggestion: save your data point one per line in a file "my_data_points.dat"
and read from the file. "echo" will do that, too.
Hope that helps and have fun,
On 11 Jan 2008, at 16:35, sokol dervishi wrote:
Thank you very much for your help Thomas, It was very helpful for me...
  Best Regards,
  Sokol
Hello everyone,
"for ..." loop:
do
{MF}.out
done
and "light.rad"
Never miss a thing. Make Yahoo your homepage.
