Ambient file corrupted?
I'm seeing 'warning - ambient file "sens.amb" corrupted near character 229' on rsensor runs. Stock 4.0 Radiance, FreeBSD 7.3, AMD Operton. Do I need to worry about this? Any idea what's causing it?
Randolph M. Fritz • RFritz@lbl.gov
Yes, you should worry about it. An ambient file can be corrupted by poor synchronization between processes that are sharing it. If your file is corrupted at character 229, that's right near the beginning of the file, which means the whole thing is probably trashed and should be removed.
Date: October 12, 2010 5:46:49 PM PDT
Thanks, Greg. Is there any way to debug this further?
Randolph
Hi Randolph,
You can look at what's in the corrupted file using the lookamb utility. You really need to figure out what corrupted it, though, which means repeating the operations/runs you did on this file and seeing if it happens again.
Date: October 13, 2010 10:09:10 AM PDT
Randolph
Thanks; that makes sense. The problem seems to occur consistently with rsensor. Is rsensor just not supposed to use ambient files? Or would you like me to look further?
Randolph
On 2010-10-13 10:57:32 -0700, Greg Ward said:
Hi Randolph,
Randolph
