Alternative shells for Windows
Hi Urtza,
Linux is preferable above windows for using Radiance. We have very good experiences with our students using a virtual linux machine under windows 7.
We are using the "Oracle VM VirtualBox Manager" with Ubuntu. For our students we have prepared an Image (Appliance) with all necessary programs in it for running Radiance, Evalglare and some handy scripts.
Kind regards,
Jan
Sent: maandag 18 mei 2015 21:00
Subject: Radiance-general Digest, Vol 135, Issue 25
Today's Topics:
   1. Re: Alternative shells for Windows (WAS: Re: rcontrib for
      rendering - missing required modifier argument)
      ([email protected])
   2. Re: Alternative shells for Windows (WAS: Re: rcontrib for
      rendering - missing required modifier argument) (Guglielmetti, Robert)
Message: 1
Date: Mon, 18 May 2015 09:44:07 +0200
Subject: Re: [Radiance-general] Alternative shells for Windows (WAS:
  Re: rcontrib for rendering - missing required modifier argument)
Message-ID:
  <[email protected]>
Content-Type: text/plain; charset="utf-8"; Format="flowed";
  DelSp="Yes"
Hi everybody,
Thanks for your suggestions. I have a doubt for a month when I have started
using Radiance. Is Linux advisable to use for Radiance? Perhaps, it may in
the long run be better.
Kind regards!
Urtza.
"Guglielmetti, Robert" <[email protected]> escribi?:
Hi Chris,
The main advantages I see in using Git's Bash shell for Windows are
smaller footprint, easier installation, and tighter integration. I
haven't
done extensive testing, but it seems like the Git Bash shell gives
Windows
users a more similar and compatible experience to that of the Unix user,
potentially allowing folks to use things like Andy McNeil's tutorials,
as-written.
The installer is 17MB and just *works*, adding a shortcut to a "Git Bash"
command prompt. Once fired up, you have access to your existing file
system, and all the basic CLI tools a Unix user us used to (e.g. ls) are
there and just work, along with things like wildcards. =) There's no
other
system tuning to do. I haven't used or set up Cygwin in a long time but
this Git shell is a lot easier than the Cygwin I've used. I still haven't
tested any of the more esoteric Radiance command pipelines (such as
what's
used to get view parameters passed to rcontrib), but ASSuming they work,
coupled with a Windows Python or Ruby interpreter I'd bet you can get
pretty close to the Unix experience on Windows with little brain damage
now.
Having said all that, there are still things that the Windows user gives
up in RadianceLand. The built-in multithreading (in rcontrib, rtrace,
rpict, et al.) doesn't work; there are a few remaining Radiance commands
that are written in csh so those (probably (might?)) won't work; native
manpage support is lacking; and Roland had to use some sub-optimal
functions to get all the photon map stuff to build on Windows. Still, I
think we've come a long way?
On 5/15/15, 11:40 AM, "Christopher Rush" <[email protected]> > wrote:
Rob,
Getting off-topic, but not sure if it warrants a separate thread... you
imply that we can run Radiance commands in the Git for Windows bash
shell. Is there an advantage to doing so, in comparison to Cygwin (which
I have used in the past)? Both would have the clear advantages of being
able to use more powerful scripted commands when compared to the Windows
cmd prompt, but Git-bash is more lightweight while Cygwin would be more
powerful (for things unrelated to Radiance?)? In both cases install
according to normal Windows Radiance installation and adjust paths as
necessary in each environment?
-Chris
Sent: Friday, May 15, 2015 11:55 AM
Welp, it appears that the '*' wildcard expansion does not work with
Windows in the standard shell, even though the wildcard does work with
other internal commands, such as 'type' (Windows-speak for 'cat'). As
they say: WTF?
P.S. The wildcard does expand correctly with pcompos in a Cygwin shell,
so there's that.
P.P.S. You can install a lightweight Cygwin shell by simply installing
Git for Windows (https://msysgit.github.io/). You get a proper BASH
shell
in Windows with minimal effort. Highly recommended.
Electronic mail messages entering and leaving Arup? business
[email protected]://www.radiance-online.org/mailman/listinfo/radiance-general
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20150518/95f4f369/attachment-0001.html>
Message: 2
Date: Mon, 18 May 2015 15:52:07 +0000
Message-ID: <D17F657B.195A3%[email protected]>
Content-Type: text/plain; charset="iso-8859-2"
If you can get ahold of a Unix-based system, be it a Mac running OSX or a Linux system, your experience will likely be better, yes. But I do think that with the latest installer we provide here (https://github.com/NREL/Radiance/releases/tag/5.0.a.3) and the "Git Bash shell" from here (https://msysgit.github.io/), you could get pretty darn close to the same experience as you would on *nix.
Good luck!
On 5/18/15, 1:44 AM, "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>> wrote:
Hi everybody,
Thanks for your suggestions. I have a doubt for a month when I have started using Radiance. Is Linux advisable to use for Radiance? Perhaps, it may in the long run be better.
Kind regards!
Urtza.
"Guglielmetti, Robert" <[email protected]<mailto:[email protected]>> escribi?:
Hi Chris,
smaller footprint, easier installation, and tighter integration. I haven't
done extensive testing, but it seems like the Git Bash shell gives Windows
as-written.
there and just work, along with things like wildcards. =) There's no other
tested any of the more esoteric Radiance command pipelines (such as what's
now.
On 5/15/15, 11:40 AM, "Christopher Rush" <[email protected]<mailto:[email protected]>> wrote:
Rob,
-Chris
From: Guglielmetti, Robert [mailto:[email protected]<mailto:[email protected]>]
they say: WTF?
so there's that.
Git for Windows (https://msysgit.github.io/). You get a proper BASH shell
Radiance-general@radiance-online<mailto:Radiance-general@radiance-online>.orghttp://www.radiance-online.org/mailman/listinfo/radiance-general
End of Radiance-general Digest, Vol 135, Issue 25
Hi Jan,
Thank you for sent information.
I am thinking to do something similar.
Best wishes,
Urtza.
"Diepens, J.F.L." <[email protected]> escribió:
Hi Urtza,
windows 7.
Kind regards,
Jan
Today's Topics:
([email protected])
Robert)
Message: 1
argument)
Message-ID:
<[email protected]>
DelSp="Yes"
Hi everybody,
started
in
Kind regards!
Urtza.
Hi Chris,
haven't
Windows
as-written.
Bash"
other
haven't
what's
now.
Rob,
(which
Windows
-Chris
they say: WTF?
so there's that.
shell
URL:
Message: 2
argument)
Good luck!
Hi everybody,
Kind regards!
Urtza.
escribi?:
Hi Chris,
haven't
Windows
as-written.
other
what's
now.
Rob,
-Chris
[mailto:[email protected]<mailto:[email protected]>][1]
they say: WTF?
so there's that.
Radiance-general@radiance-online<mailto:Radiance-general@radiance-online>.PGEgaHJlZj0ib3JnaHR0cDovL3d3dy5yYWRpYW5jZS1vbmxpbmUub3JnL21haWxtYW4vbGlzdGluZm8vcmFkaWFuY2UtZ2VuZXJhbCIgdGFyZ2V0PSJfYmxhbmsiPm9yZ2h0dHA6Ly93d3cucmFkaWFuY2Utb25saW5lLm9yZy9tYWlsbWFuL2xpc3RpbmZvL3JhZGlhbmNlLWdlbmVyYWw8L2E+[2]
Vínculos:
On 5/18/15, 1:44 AM, > "[email protected]<mailto:[email protected]>" > <[email protected]<mailto:[email protected]>> wrote:
On 5/15/15, 11:40 AM, "Christopher Rush" > <[email protected]<mailto:[email protected]>> wrote:
[1] mailto:[email protected]>%5D
[2] mailto:Radiance-general@radiance-online>.%EF%BF%BD%EF%BF%BD%EF%BF%BDPGEgaHJlZj0ib3JnaHR0cDovL3d3dy5yYWRpYW5jZS1vbmxpbmUub3JnL21haWxtYW4vbGlzdGluZm8vcmFkaWFuY2UtZ2VuZXJhbCIgdGFyZ2V0PSJfYmxhbmsiPm9yZ2h0dHA6Ly93d3cucmFkaWFuY2Utb25saW5lLm9yZy9tYWlsbWFuL2xpc3RpbmZvL3JhZGlhbmNlLWdlbmVyYWw8L2E+%EF%BF%BD%EF%BF%BD%EF%BF%BD
