about luminaire modeling
Hello, here pillo with some problems...
the topic is luminaire modeling.
1) i created .dat file (from unknown file format received) with luminous intensities (cd) for 1000 lm flux.
2 angles declared explicitly. (phi & theta are in the right order...)
2) i created .rad file with:
1 sphere (surface equals to .0056419m @ 10m hight ) as light geometry
the ground @0m height
the light material has this definition:
void brightdata dist
5 corr source.dat source.cal src_phi2 src_theta
1 2681
dist light point
3 1 1 1
where 2681 is from: (1/179 * 48000lm/1000lm * 10000)
i m working with 1 * 400W SAT and a sphere of radius equals to .0056419....)
NOW THE QUESTION:
i used rtrace to calculate orizontal illuminance (echo "x y z 0 0 1" | rtrace -I+ *.oct):
the point under the light (theta is 0) gives the same value i computed manually:
illuminance = intensity/height^2 * cos theta where theta = 0)
the bad thing is that points with different angles give not right values ( i tried 45° and 30° that are from .dat file)
(i got an error 10% plus or minus)
what's the matter???
some rtrace's settings.... what else?
thanks for every kind of advice you'll gave me
pillo (g.antonutto)
IT WAS MY FAULT:
no matters but ME!!!!
i calculated illuminance @wrong points... so the fix was to think before click.. (point (-10 0 0) is not (0 -10 0) ......)
thanks again,
pillo
1 2681
dist light point
3 1 1 1
NOW THE QUESTION:
pillo (g.antonutto)
