60Watt bulb comparison
John
Thanks for the useful info.
I had to construct a small black box (0.5 cube) for calibrating electronic
sensors I am currently using to monitor a full scale light pipe
installation, which in turn will be compared with a Radiance model thereof.
Furthermore, Recent research (Maamari et al. 2003) shows that a cube dark
box with an
opening central to one of the walls is most appropriate for simulation
modelling
comparison because reflectance values are minimal and easily measured, and
modelling complexities and associated anomalies are minimised. Conventional
modelling architectural black/white card display board. The reflectance
value for black mounting board was measured by Cannon-Brookes (1996) and is
quoted at 8.5%. A standard 60W incandescent light bulb was also fitted to
the dark box to fit into the recessed aperture, and was made removable for
daylight monitoring whereby the recessed aperture acted as a window or sky
light (without glass). I take your points though, that scale will influence
the final results, and in absence of good data for the GE 60W standard light
bulb I am using, its not good scientific comparison.
Anyway, I am more interested in the accuracy of the program with respect to
*daylight* rather than electric lighting. To date, I can only locate your
own work to the accuracy of the Radiance accuracy with daylight (as in the
RwR manual)...
Just on this point....does anyone know of any other references that have
compared daylight measurements with Radiance? would be great to include them
in my literature review.
It would be nice to model this simple box I have constructed in two
positions = recessed roof light, and recessed side window, facing each
orientation on overcast and sunny days. I could then create the model of the
box to scale (1=1) in Radiance and compare results with monitored values on
the roof of the campus building here in Dublin. What do you think about
this? or can you suggest some ways of enhancing the tests?
Kind Regards,
Anthony
Dublin Institute of Technology
[mailto:[email protected]]On Behalf Of
Sent: 30 June 2004 18:05
Subject: Radiance-general Digest, Vol 4, Issue 26
Today's Topics:
   1. RE: 60Watt bulb luminaries data (Anthony J. Farrell)
   2. RE: 60Watt bulb luminaries data (John Mardaljevic)
   3. RE: 60Watt bulb luminaries data (Martin Moeck)
   4. Re: colorpict and materials (Lars O. Grobe)
Message: 1
Date: Wed, 30 Jun 2004 12:42:55 +0100
Subject: [Radiance-general] RE: 60Watt bulb luminaries data
Content-Type: text/plain; charset=us-ascii
I am currently carrying out basic validation techniques of the Radiance
software using a black box and standard 60Watt bulb therein.
I cannot locate a standard incandescent 60W bulb (just bare hung from
ceiling, no lamp shade) on the desktop radiance program.
Can anyone help me by way of an add on file for a standard light bulb (even
if not 60W!) or refer me to a suitable IESNA file?
Kind regards
Anthony
Sent: 30 June 2004 10:59
Subject: Radiance-general Digest, Vol 4, Issue 25
Today's Topics:
   1. Re: Illuminance calculation on a virtual surface? ([email protected])
   2. Re: colorpict and materials (Lars O. Grobe)
   3. Re: colorpict and materials (Jack de Valpine)
Message: 1
Date: Tue, 29 Jun 2004 04:18:48 -0700
Subject: Re: [Radiance-general] Illuminance calculation on a virtual
  surface?
To: [email protected], Radiance general discussion
  <[email protected]>
Content-Type: text/plain; charset=ISO-8859-1
OK, Rob -- you got me. Your little trick would work. I don't think he
really needs it, though, since he already has a method for generating
the grid points for rtrace. He can simply increase the resolution of
the grid he already has (as Raphael suggested) and/or upsample the
result using pfilt. Or your method. All will work.
Quoting Rob Guglielmetti <[email protected]>:
Hi Greg, Hi John,
Greg Ward wrote:
> No good. Trans gets ignored by the rpict -i option. Just use pfilt to
> scale the illuminance map if it's not big enough. (John M's suggestion
> -- he's sitting next to me in Leicester.)
Oh yeah? =8-p
vwrays -x XRES -y YRES -vf viewfile -fd | rtrace -h -fd -opn octree \
> rtrace -fdc -I render_options -x XRES -y YRES octree > illum_picture.pic
Greg, does this look familiar? A little ditty from a year or so ago?
You sent me this tip when I asked you how to get illuminance on a
building's curtain wall. The first rtrace computes the intersection
point (which is fast) and the second rtrace does the illuminance
calculation. Cool, yes? Yes.
Now, given this little tip, could he use trans as I described?
Message: 2
Date: Tue, 29 Jun 2004 14:34:03 +0300
Subject: Re: [Radiance-general] colorpict and materials
Content-Type: text/plain; charset=US-ASCII; format=flowed
sorry, so again, I try to be clear in asking this time :wink: By the way,
have nice holidays (I hope that's the reason for your travel ;-)!
All is about the question how to map pictures onto a surface without
corrupting its material properties. I understand that colorpict
multiplies the material color components with those of the picture.
If I have a grayscale image processed by normpat (which means that the
average gray value is 1.0) and apply it to a material, the overall
color and brightness will remain the same. So I get the "pattern" from
the image, but the surface still has the correct material properties
(color, brightness etc). I used this so far.
Now I want to use a colored picture for mapping. I also apply normpat
to it, so, as far as I understand, the average of all R, G and B must
be 1.0, right? For example, I use a normpat'ed picture of green marble.
I than apply this using colorpict to a surface, which has a "marble"
material. Will the overall color and brightness still be that of the
defined material, as the picture map has the average of 1.0?
The background: I try to use exact data for material definitions, but
the image maps can't all be color corrected. So I want the overall
color and brightness from defined materials, e.g. from the plastic
material, and use the map only for what I would call "local color
variation". The reason is that I have e.g. red marble, got its color,
brightness and all that defined as plastic marble. But the marble has
blue particles which won't appear if I use a grayscale imagemap. So I
want to use a normpat'ed (NOT colorcorrected e.g. by macbethcal!) to
bring these blue parts onto the surface. The whole surface however must
still have the average color of my plastic marble material.
If I understand the man-page of normpat, that's just what it was
invented for. However, I am a bit unsure, as all Radiance documentation
uses colorpict with a bright white material.
TIA+CU, Lars.
Lars O. Grobe
Message: 3
Date: Tue, 29 Jun 2004 09:38:59 -0400
Hi Lars,
I believe that what you need to do is take your colorpict modifier and
apply it to a material such as a plastic that uses the reflectance of
your material sample as the rgb parameters. I believe that you DO want
to use macbethcal to callibrate the color values of the image and
determine an estimated reflectance. Then using normpat on the image will
move the values in image so the average is 1.0.
So steps as follows:
   1. acquire sample material image by photography, scan....
   2. callibrate sample image with macbethcal
   3. use callibrated sample image to estimate average color
   4. calculate reflectance based on average color values, grey(r,g,b)
   5. normpat the callibrated image
Then create material as follows:
void colorpict color.image.pattern
7 red green blue <normpat picture>.pic picture.cal Px Py
1 <aspect>
color.image.pattern plastic color.image.material
5 <grey(r,g,b)> <grey(r,g,b)> <grey(r,g,b)> <s> <r>
Since the colorpict is normalized to an average value of one, it will
modify the plastic around the reflectance of the plastic. For example,
if colorpict returns 1.1 for red then the red of the plastic will be 10%
brighter.
In short I think that there are two main ways to use colorpict
   1. final reflectance set by colorpict image - colorpict is used to
      set final reflectance of material, that is use callibrated image
      colorpict modifier and material with reflectance of 1.0
   2. final reflectance set by base material - colorpict is used to
      modify reflectance set by material, that is normpat image
      colorpict modifier is used to modify reflectance set by material
I hope this is helpful.
Lars O. Grobe wrote:
marble. I than apply this using colorpict to a surface, which has a
"marble" material. Will the overall color and brightness still be that
of the defined material, as the picture map has the average of 1.0?
must still have the average color of my plastic marble material.
documentation uses colorpict with a bright white material.
TIA+CU, Lars.
Lars O. Grobe
# John E. de Valpine
URL:
http://radiance-online.org/pipermail/radiance-general/attachments/20040629/d
b72607e/attachment.html
End of Radiance-general Digest, Vol 4, Issue 25
This message has been scanned for content and
viruses by the DIT Information Services MailScanner
Service, and is believed to be clean.
http://www.dit.ie
http://www.dit.ie
Message: 2
Date: Wed, 30 Jun 2004 14:32:15 +0100 (BST)
Content-Type: TEXT/plain; charset=us-ascii
Anthony,
Wait a moment whilst the spots before my eyes subside. Ah, that's better.
(even
The results you get are likely to depend on the size of the box
and the type of lamp, not to mention a few other factors.
You could model the bulb as a luminous sphere. But you'd have to know
what the luminance of the bulb was. Also, a sphere light source is not
subdivided, i.e. it is sampled by a single ray (p511 RwR). Which may
cause problems if the box is small compared to the bulb. A 'frosted'
or pearl bulb may have a largely isotropic luminous output, provided you
don't see too much of the (luminous) shank where it connects to the
socket. Any measured output distribution (say, IENSA) would, I guess,
be sensitive to the type of lamp. And it would assume a 'point source'
distribution, even though you would model it as, say, a disc or polygon.
Squinting at my desk lamp through a pinched-finger aperture (hence the
spots) revealed that the uniform luminance of the pearl bulb was an
illusion - much of the output of the bulb is from around the filament.
In sort, I suspect that any comparison between measurement and predictions
for your bulb & box will say much about the precision of the photometry,
maybe a little bit about the limitations of single ray light source
sampling,
and not much at all about the intrinsic accuracy of Radiance for realistic
architectural scenarios (electric or daylighting). The direct light source
calculation for small angular light sources (e.g. 'spherical' bulb from
several feet away with no occlusion) is pretty much a 'no brainer' and
Radiance will give a result that is near as dammit to the exact solution.
When you get close up to a non-ideal bulb however, then it's a matter of
getting the photometry right.
-John
Dr. John Mardaljevic
Senior Research Fellow
De Montfort University
The Gateway
Leicester
LE1 9BH, UK
+44 (0) 116 257 7972
+44 (0) 116 257 7981 (fax)
http://www.iesd.dmu.ac.uk/~jm
Message: 3
Date: Wed, 30 Jun 2004 12:07:27 -0400
To: "Radiance general discussion"
  <[email protected]>
Message-ID:
  <[email protected]>
Anthony,
You can download an IES photometric file for a PAR 60W incandescent narrow
flood from Osram Sylvania at
www.personal.psu.edu/mum13/60PAR30.CAP.NFL25.ies
<http://www.personal.psu.edu/mum13/60PAR30.CAP.NFL25.ies>
Use "ies2rad 60PAR30.CAP.NFL25.ies"
This will create the file "60PAR30.CAP.NFL25.rad" in metric units (meters).
I never saw photometric files for simple incandescent lamps.
I am currently running a fairly accurate simulation in AGI32 V1.7, which
will complete in 3 hours for a simple empty box 3X3X3 meters and one PAR
lamp.
Martin Moeck, Penn State
  From: Anthony J. Farrell [mailto:[email protected]]
  Sent: Wed 6/30/2004 7:42 AM
  Cc:
  Kind regards
  Anthony
Name: not available
Type: application/ms-tnef
Desc: not available
Url :
http://radiance-online.org/pipermail/radiance-general/attachments/20040630/0
51f97e3/attachment-0001.bin
Message: 4
Date: Wed, 30 Jun 2004 20:06:58 +0300
Hi Jack,
thank You for the reply.
modify reflectance set by material, that is normpat image colorpict
I want to do this, I have the material values, the colorpict is just to
add some visual credibility :wink: But I also want to have the final
overall (that means the average over the whole surface, like selecting
an area in ximage vs. a point) color from the base material.
So, if I already have the rgb for the base material (which is plastic),
do I really have to calibrate (macbethcal) the picture map?
Maybe I show you an example:
# porphyry red 1: values from ximage and macbethcal'ed pic
void plastic porphyry_red_1
5 .09 .06 .05 .02 0
# non-calibrated normpat'ed pic
void colorpict sophia_porphyry_red_1_pattern
13 noop noop noop sophia_porphyry_red_1.pic picture.cal tile_u tile_v
-s .2 -rx 90 -rz 90
# give alias the modifier as output from dxf2rad
sophia_porphyry_red_1_pattern alias l_porphyry_red_1 porphyry_red_1
Will this be correct?
TIA, CU Lars.
Lars O. Grobe
End of Radiance-general Digest, Vol 4, Issue 26
http://www.dit.ie
http://www.dit.ie
Hi Anthony,
A few references re validation of Radiance under daylight conditions:
Mardaljevic, J. (1995), Validation of a lighting simulation program under real sky conditions, Lighting Res Technol, 27 (4), 181-188.
Mardaljevic, J. (2000), Daylight simulation: validation, sky models and daylight coefficients, PhD thesis, De Montfort University, Leicester.
Jarvis, D. and Donn, M. (1997), Comparison of computer and model simulations of a daylit interior with reality, Building Performance and Simulation Assoc Conf., Prague.
Fontoynont, M., Laforgue, P., Mitanchey, R., Aizlewood, M.E., Butt, J., Carroll, W., Hitchcock, R., Erhorn, H., De Boer, J., Michel, L., Scartezzini, J.-L., Bodart, M., and Roy, G.G. (1999), Validation of daylighting simulation programs, IEA SHC Task 21, Vaulx-en-Velin.
Hopefully you can find some of these.
Phil.
From: [email protected] [mailto:[email protected]] On Behalf Of Anthony J. Farrell
Sent: Thursday, 1 July 2004 4:47 AM
Subject: [Radiance-general] RE: 60Watt bulb comparison
John
I had to construct a small black box (0.5 cube) for calibrating electronic sensors I am currently using to monitor a full scale light pipe installation, which in turn will be compared with a Radiance model thereof.
Furthermore, Recent research (Maamari et al. 2003) shows that a cube dark box with an opening central to one of the walls is most appropriate for simulation modelling comparison because reflectance values are minimal and easily measured, and modelling complexities and associated anomalies are minimised. Conventional modelling architectural black/white card display board. The reflectance value for black mounting board was measured by Cannon-Brookes (1996) and is quoted at 8.5%. A standard 60W incandescent light bulb was also fitted to the dark box to fit into the recessed aperture, and was made removable for daylight monitoring whereby the recessed aperture acted as a window or sky light (without glass). I take your points though, that scale will influence the final results, and in absence of good data for the GE 60W standard light bulb I am using, its not good scientific comparison.
*daylight* rather than electric lighting. To date, I can only locate your own work to the accuracy of the Radiance accuracy with daylight (as in the RwR manual)...
Just on this point....does anyone know of any other references that have compared daylight measurements with Radiance? would be great to include them in my literature review.
It would be nice to model this simple box I have constructed in two positions = recessed roof light, and recessed side window, facing each orientation on overcast and sunny days. I could then create the model of the box to scale (1=1) in Radiance and compare results with monitored values on the roof of the campus building here in Dublin. What do you think about this? or can you suggest some ways of enhancing the tests?
Kind Regards,
Anthony
[mailto:[email protected]]On Behalf Of [email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of Radiance-general digest..."
Today's Topics:
Message: 1
Date: Wed, 30 Jun 2004 12:42:55 퍝
I am currently carrying out basic validation techniques of the Radiance software using a black box and standard 60Watt bulb therein.
I cannot locate a standard incandescent 60W bulb (just bare hung from ceiling, no lamp shade) on the desktop radiance program.
Can anyone help me by way of an add on file for a standard light bulb (even if not 60W!) or refer me to a suitable IESNA file?
Kind regards
Anthony
Today's Topics:
Message: 1
  surface?
  <[email protected]>
OK, Rob -- you got me. Your little trick would work. I don't think he really needs it, though, since he already has a method for generating the grid points for rtrace. He can simply increase the resolution of the grid he already has (as Raphael suggested) and/or upsample the result using pfilt. Or your method. All will work.
Hi Greg, Hi John,
> to scale the illuminance map if it's not big enough. (John M's
> suggestion
Oh yeah? =8-p
> illum_picture.pic
Message: 2
Date: Tue, 29 Jun 2004 14:34:03 퍽
sorry, so again, I try to be clear in asking this time :wink: By the way, have nice holidays (I hope that's the reason for your travel ;-)!
All is about the question how to map pictures onto a surface without corrupting its material properties. I understand that colorpict multiplies the material color components with those of the picture.
If I have a grayscale image processed by normpat (which means that the average gray value is 1.0) and apply it to a material, the overall color and brightness will remain the same. So I get the "pattern" from the image, but the surface still has the correct material properties (color, brightness etc). I used this so far.
Now I want to use a colored picture for mapping. I also apply normpat to it, so, as far as I understand, the average of all R, G and B must be 1.0, right? For example, I use a normpat'ed picture of green marble.
material. Will the overall color and brightness still be that of the defined material, as the picture map has the average of 1.0?
The background: I try to use exact data for material definitions, but the image maps can't all be color corrected. So I want the overall color and brightness from defined materials, e.g. from the plastic material, and use the map only for what I would call "local color variation". The reason is that I have e.g. red marble, got its color, brightness and all that defined as plastic marble. But the marble has blue particles which won't appear if I use a grayscale imagemap. So I want to use a normpat'ed (NOT colorcorrected e.g. by macbethcal!) to bring these blue parts onto the surface. The whole surface however must still have the average color of my plastic marble material.
If I understand the man-page of normpat, that's just what it was invented for. However, I am a bit unsure, as all Radiance documentation uses colorpict with a bright white material.
TIA, Lars.
Lars O. Grobe
Message: 3
Hi Lars,
I believe that what you need to do is take your colorpict modifier and apply it to a material such as a plastic that uses the reflectance of your material sample as the rgb parameters. I believe that you DO want to use macbethcal to callibrate the color values of the image and determine an estimated reflectance. Then using normpat on the image will move the values in image so the average is 1.0.
7 red green blue <normpat picture>.pic picture.cal Px Py 0
1 <aspect>
color.image.pattern plastic color.image.material 0 0
Since the colorpict is normalized to an average value of one, it will modify the plastic around the reflectance of the plastic. For example, if colorpict returns 1.1 for red then the red of the plastic will be 10% brighter.
TIA, Lars.
Lars O. Grobe
URL:
This message has been scanned for content and viruses by the DIT Information Services MailScanner Service, and is believed to be clean.
http://www.dit.ie
http://www.dit.ie
Message: 2
Date: Wed, 30 Jun 2004 14:32:15 퍝 (BST)
Anthony,
(even
The results you get are likely to depend on the size of the box and the type of lamp, not to mention a few other factors.
You could model the bulb as a luminous sphere. But you'd have to know what the luminance of the bulb was. Also, a sphere light source is not subdivided, i.e. it is sampled by a single ray (p511 RwR). Which may cause problems if the box is small compared to the bulb. A 'frosted'
or pearl bulb may have a largely isotropic luminous output, provided you don't see too much of the (luminous) shank where it connects to the socket. Any measured output distribution (say, IENSA) would, I guess, be sensitive to the type of lamp. And it would assume a 'point source'
spots) revealed that the uniform luminance of the pearl bulb was an illusion - much of the output of the bulb is from around the filament.
In sort, I suspect that any comparison between measurement and predictions for your bulb & box will say much about the precision of the photometry, maybe a little bit about the limitations of single ray light source sampling, and not much at all about the intrinsic accuracy of Radiance for realistic architectural scenarios (electric or daylighting). The direct light source calculation for small angular light sources (e.g. 'spherical' bulb from several feet away with no occlusion) is pretty much a 'no brainer' and Radiance will give a result that is near as dammit to the exact solution.
When you get close up to a non-ideal bulb however, then it's a matter of getting the photometry right.
-John
Institute of Energy and Sustainable Development De Montfort University The Gateway Leicester
LE1 9BH, UK
(0) 116 257 7972
Message: 3
  <[email protected]>
Message-ID:
  <[email protected]>
Anthony,
You can download an IES photometric file for a PAR 60W incandescent narrow flood from Osram Sylvania at
I am currently running a fairly accurate simulation in AGI32 V1.7, which will complete in 3 hours for a simple empty box 3X3X3 meters and one PAR lamp.
  Cc:
  Kind regards
  Anthony
Name: not available
Desc: not available
Url :
Message: 4
Date: Wed, 30 Jun 2004 20:06:58 퍽
Hi Jack,
I want to do this, I have the material values, the colorpict is just to add some visual credibility :wink: But I also want to have the final overall (that means the average over the whole surface, like selecting an area in ximage vs. a point) color from the base material.
So, if I already have the rgb for the base material (which is plastic), do I really have to calibrate (macbethcal) the picture map?
# porphyry red 1: values from ximage and macbethcal'ed pic void plastic porphyry_red_1 0 0
5 .09 .06 .05 .02 0
13 noop noop noop sophia_porphyry_red_1.pic picture.cal tile_u tile_v -s .2 -rx 90 -rz 90 0 0
# give alias the modifier as output from dxf2rad sophia_porphyry_red_1_pattern alias l_porphyry_red_1 porphyry_red_1
TIA, CU Lars.
Lars O. Grobe
http://www.dit.ie
http://www.dit.ie
Anthony,
Yep, 0.5 (m) is small compared to the bulb diameter.
box with an
modelling
Actually, I believe this scenario was used becuase it was simple enough
for there to be an exact analytical solution. It's not really "appropriate"
at all for any real world example.
RwR manual)...
What can I say? The validation I carried out is reckoned to be the most
rigorous yet for daylight modelling. Enough people have said so that I'm
inclined to believe them. Of course, this is largely becuase I had access
to an excellent (still unique?) test dataset from the BRE. It's described
here in gory detail:
http://www.iesd.dmu.ac.uk/~jm/zxcv-thesis/
There's no question that Radiance is *capable* of high accuracy predictions
provided that it is driven correctly - at least for the great number of plausible
architectural scenarios that are not too dissimilar from the validation scenario.
The tricky part is determining the extent of what I call the "domain of validity"
of the validation scenario. In other words, how different from the validation scenario
does a scene have to be so that we begin to question the software's capacity to
deliver an accurate result? (Rather than our own ability to describe the scene
with sufficient precision or drive the simulation correctly.) This and other
validation topics are addressed in the paper:
"Verification of Program Accuracy for Illuminance Modelling: Assumptions, Methodology
and an Examination of Conflicting Findings (2004) Lighting Res. Technol. (in press)
It should be out in a few months.
-John
The Gateway
Leicester
LE1 9BH, UK
