5-phase method - Direct daylight matrix
My question is regarding the 5-phase method tutorial, example 1, section
6.6. I was wondering why glazing.rad is not included in the all black model
of the direct daylight matrix (after "-").
Leyla
Hi Leyla,
This section computes the direct component of the three-phase method in
order to subtract it out. The transmission properties of glazing.rad are
contained in the BSDF (bsdf/fullwindow.xml) and is applied in the second
dctimestep command in section 6.8.
Andy
On Sun, Nov 10, 2013 at 8:21 PM, Leyla Sanati <[email protected]> wrote:
model of the direct daylight matrix (after "-").
Leyla
Thank you Andy for your response.
Sorry if this sounds dumb. I just want to make sure I am doing it right.
So in the all black model, I include all of the window assembly elements
(window frame, mullions, shading devices) Except for the glass.
Leyla
On Mon, Nov 11, 2013 at 1:42 PM, Andrew McNeil <[email protected]> wrote:
Hi Leyla,
Andy
On Sun, Nov 10, 2013 at 8:21 PM, Leyla Sanati <[email protected]>wrote:
Leyla
Hi Leyla,
Assuming the window frame, mullions and shading devices are contained in
the BSDF data, no you don't need those either.
Andy
Leyla
Hi Leyla,
Andy
Leyla
Andy,
Thank you for clarification. I guess I was confused because I noticed you
had the venetian blinds in your all black model, while it was already
contained in your BSDF. It must have slipped there from previous parts.
$ xform -m black objects/testroom_Swall.rad objects/testroom.rad
objects/ground.rad
\ *objects/venetianblind.rad *| oconv materials/testroom.mat -
objects/viewmtxsurf.rad
\ objects/daymtxsurf.rad skies/sky_white.rad > octs/model_allblack.oct
Leyla
On Mon, Nov 11, 2013 at 7:14 PM, Andrew McNeil <[email protected]> wrote:
Hi Leyla,
Andy
Leyla
Hi Leyla,
Andy
section 6.6. I was wondering why glazing.rad is not included in the
all black model of the direct daylight matrix (after "-").
Leyla
You don't need to include the venetian blinds in that model, but since it
was between the daylight and view matrix polygons it doesn't hurt to
include it.
Andy
On Tue, Nov 12, 2013 at 6:23 AM, Leyla Sanati <[email protected]> wrote:
Andy,
objects/ground.rad
Leyla
Hi Leyla,
Andy
right. So in the all black model, I include all of the window assembly
elements (window frame, mullions, shading devices) Except for the glass.
Leyla
Hi Leyla,
Andy
Leyla
Yes. It makes sense.
Now, may I a question about the direct sun coefficient matrix. I have a
model with windows facing south, west and north and varying shading devices
for each orientation.
Should I create a separate direct sun coefficient matrix for each window
orientation, or would it be correct if I create an all-black model
containing all of the shading devices and pass it to rcontrib. Something
like this:
xform -m black room.rad objects/ground.rad | oconv materials/room.mat -
objects/glazing.rad objects/shading_south.rad objects/shading_west.rad
objects/glazing_bsdf_south.rad objects/glazing_bsdf_west.rad
objects/glazing_bsdf_north.rad
skies/suns.rad > octs/model_suns.oct
*rcontrib < data/photocells.pts -I -ab 1 -ad 65536 -lw 1.52e-5 -dc 1 -dt 0
-dj 0 -st 1 -ss 0 -faf -e MF:6 -f reinhart.cal -b rbin -bn Nrbins -m solar
octs/model_suns.oct > matrices/directsun.dsmxThank you,Leyla*
include it.
Andy
On Tue, Nov 12, 2013 at 6:23 AM, Leyla Sanati <[email protected]>wrote:
Andy,
objects/ground.rad
Leyla
Hi Leyla,
Andy
Leyla
Hi Leyla,
in order to subtract it out. The transmission properties of glazing.rad
are contained in the BSDF (bsdf/fullwindow.xml) and is applied in the
second dctimestep command in section 6.8.
Andy
Leyla
If you want to control shading separately for each orientation than you
need a separate run for each window group. You also need a separate model
for each shading state. But if all are controlled together or if there is
no active shading than one model is fine.
Andy
like this:
octs/model_suns.oct > matrices/directsun.dsmx Thank you, Leyla*
include it.
Andy
Andy,
you had the venetian blinds in your all black model, while it was already
objects/ground.rad
Leyla
Hi Leyla,
in the BSDF data, no you don't need those either.
Andy
Leyla
On Mon, Nov 11, 2013 at 1:42 PM, Andrew McNeil <[email protected]>wrote:
Hi Leyla,
Andy
Leyla
