3 phase method in Windows OS
Dear expert,
I am trying to run the Three Phase Method in Windows 8 but at the moment of
the DMX generation I have found out a problem with genklemsamp.
Searching in the web I have understood the problem regards something about
some incompatibility of the Pearl language with Windows OS. I have also
find a ZIP archives that contains Radiance Perl scripts that were packaged
into Windows executable files in the Jolaxa site.
Although I have followed the instruction (rather easy since I have only to
paste the exe file in the bin directory) something still doesn't work.
The command crash even if I run a simple case as:
genklemsamp -c 10 - vd 0 -1 0 > sample.dat
with the waring : "genklemsamp has stopped working".
Any suggestion?
Kind regards,
*Giuseppe *
This error must be generated by Perl itself, as it isn't one produced by the genklemsamp.pl script. I don't know enough about Perl and Windows to say more, but perhaps someone else does.
Subject: [Radiance-general] 3 phase method in Windows OS
Date: July 28, 2014 7:39:25 AM PDT
Dear expert,
I am trying to run the Three Phase Method in Windows 8 but at the moment of the DMX generation I have found out a problem with genklemsamp.
Searching in the web I have understood the problem regards something about some incompatibility of the Pearl language with Windows OS. I have also find a ZIP archives that contains Radiance Perl scripts that were packaged into Windows executable files in the Jolaxa site.
Although I have followed the instruction (rather easy since I have only to paste the exe file in the bin directory) something still doesn't work.
Any suggestion?
Kind regards,
Giuseppe
I've only experience with Windows XP and Windows 7, but this should all work fine if you have Perl installed properly. Get your correct version of Perl from here:
…or here:
http://strawberryperl.com/
…and make sure to add the Perl executable directory to your PATH (the installers will optionally do this for you).
You also need to ensure your Radiance installation is correct, meaning that the Radiance bin directory is in your PATH, and the Radiance lib directory is in an environment variable called "RAYPATH".
On 7/28/14, 9:57 AM, "Greg Ward" <[email protected]<mailto:[email protected]>> wrote:
From: Giuseppe De Michele <[email protected]<mailto:[email protected]>>
Dear expert,
Any suggestion?
Kind regards,
Giuseppe
Dear Rob and Andy,
Thank you for the help. The interpreter for Pert is what I need.
Although with my colleague we have found an other problem, the same find in
this discussion:
http://www.radiance-online.org/pipermail/radiance-general/2013-July/009660.html
and after replacing the wrong string with the right one ,finally, all seems
works well.
Also in couple with rcontrib.
So thank again expert,
Giuseppe
2014-07-28 18:08 GMT+02:00 Guglielmetti, Robert < [email protected]>:
Perl from here:
http://www.activestate.com/activeperl/downloads
…or here:
On 7/28/14, 9:57 AM, "Greg Ward" <[email protected]<mailto: > [email protected]>> wrote:
Dear expert,
Any suggestion?
Kind regards,
Giuseppe
*Giuseppe De Michele*
Dear expert,
I am here again. Unfortunately I missed the last step to complete the
simulation with the 3pm.
dctimestep gives back an error message:
  *system - header read error: no such file or directory.*
I report the steps:
*vmx*
oconv materials/materiali.rad scene/stanza.rad objects/window_glow.rad >
temp/model_vmx.oct
rcontrib -n 4 -f klems_int.cal -b kbinS -bn Nkbins -m window_glow -I+ -ab 8
-ad 10000 -as 2048 -ar 1024 -lw 1e-8 -av 0 0 0 temp/model_vmx.oct <
data/cells.pts > data/cells.vmx
*BSDF*
generated with WINDOW 7.2
*dmx*
oconv materials/materiali.rad scene/stanza.rad scene/ground.rad
scene/sky_white1.rad > temp/model_dmx.oct
genklemsamp.pl -c 1000 -vd 0 -1 0 objects/window_glow.rad | rcontrib -n 4
-c 1000 -e MF:4 -f reinhart.cal -b rbin -bn Nrbins -m sky_glow -faa
temp/model_dmx.oct > data/south.dmx
*s + dctimestep* (broken step)
gensky 6 21 15.0 -s -a 44.42 -o -8.85 -m -15.0 | genskyvec -m 4 -c 1 1 1 >
temp\skysun_4.skv
dctimestep data\cells.vmx data\bsdf\clearglass.xml data\south.dmx
temp\skysun_4.skv | rcalc -e "$1=179*($1*0.265+$2*0.670+$3*0.0065)" >
data\ill_cg.dat
The same commands work very well in UNIX environment.
I really don't know where put my hands. Any advice will be appreciate.
Giuseppe
2014-07-30 9:38 GMT+02:00 Giuseppe De Michele <[email protected]>:
Dear Rob and Andy,
in this discussion:
seems works well.
Giuseppe
[email protected]>:
Perl from here:
…or here:
On 7/28/14, 9:57 AM, "Greg Ward" <[email protected]<mailto: >> [email protected]>> wrote:
Dear expert,
Any suggestion?
Kind regards,
Giuseppe
This error could only be generated by an older version of dctimestep, as it was removed before June. I don't know if there is a way to update your binaries to make sure you have the latest, which may (or may not) solve your problem.
Subject: Re: [Radiance-general] 3 phase method in Windows OS
Date: July 30, 2014 2:59:19 AM PDT
Dear expert,
I am here again. Unfortunately I missed the last step to complete the simulation with the 3pm.
I report the steps:
vmx
oconv materials/materiali.rad scene/stanza.rad objects/window_glow.rad > temp/model_vmx.oct
rcontrib -n 4 -f klems_int.cal -b kbinS -bn Nkbins -m window_glow -I+ -ab 8 -ad 10000 -as 2048 -ar 1024 -lw 1e-8 -av 0 0 0 temp/model_vmx.oct < data/cells.pts > data/cells.vmx
BSDF
dmx
oconv materials/materiali.rad scene/stanza.rad scene/ground.rad scene/sky_white1.rad > temp/model_dmx.oct
genklemsamp.pl -c 1000 -vd 0 -1 0 objects/window_glow.rad | rcontrib -n 4 -c 1000 -e MF:4 -f reinhart.cal -b rbin -bn Nrbins -m sky_glow -faa temp/model_dmx.oct > data/south.dmx
s + dctimestep (broken step)
gensky 6 21 15.0 -s -a 44.42 -o -8.85 -m -15.0 | genskyvec -m 4 -c 1 1 1 > temp\skysun_4.skv
dctimestep data\cells.vmx data\bsdf\clearglass.xml data\south.dmx temp\skysun_4.skv | rcalc -e "$1=179*($1*0.265+$2*0.670+$3*0.0065)" > data\ill_cg.dat
Giuseppe
Dear Rob and Andy,
Although with my colleague we have found an other problem, the same find in this discussion:
and after replacing the wrong string with the right one ,finally, all seems works well.
Giuseppe
2014-07-28 18:08 GMT+02:00 Guglielmetti, Robert <[email protected]>:
…or here:
Dear expert,
Any suggestion?
Kind regards,
Giuseppe
Dear Greg,
Really before to start with the 3pm simulation in windows (last monday) I
installed, I guss, the last release for windows from:
https://github.com/NREL/Radiance/releases/tag/4.2.a.4 .
Unfortunately I am not in office now but tomorrow I am going to check the
verision.
I really hope that this is the problem.... Let's keep out finger crossed!
Giuseppe
2014-07-30 17:58 GMT+02:00 Greg Ward <[email protected]>:
your problem.
*Subject: *Re: [Radiance-general] 3 phase method in Windows OS
*Date: *July 30, 2014 2:59:19 AM PDT
Dear expert,
I report the steps:
*vmx*
temp/model_vmx.oct
*BSDF*
*dmx*
temp\skysun_4.skv
data\ill_cg.dat
Giuseppe
Dear Rob and Andy,
in this discussion:
seems works well.
Giuseppe
[email protected]>:
Perl from here:
…or here:
On 7/28/14, 9:57 AM, "Greg Ward" <[email protected]<mailto: >>> [email protected]>> wrote:
Dear expert,
Any suggestion?
Kind regards,
Giuseppe
Dear Greg,
I have found out the problem. dctimestep was recalled from the Radiance
version contained in DIVA folder (the old version as you said yesterday).
I have solved the problem simply locating the c:/radiance/bin path before
the DIVA's one in the Environment Variables.
Thanks for the helpful advice,
Giuseppe
2014-07-30 20:56 GMT+02:00 Giuseppe De Michele <[email protected]>:
Dear Greg,
verision.
Giuseppe
your problem.
Dear expert,
I report the steps:
*vmx*
temp/model_vmx.oct
*BSDF*
*dmx*
> temp\skysun_4.skv
data\ill_cg.dat
Giuseppe
Dear Rob and Andy,
in this discussion:
seems works well.
Giuseppe
[email protected]>:
Perl from here:
…or here:
On 7/28/14, 9:57 AM, "Greg Ward" <[email protected]<mailto: >>>> [email protected]>> wrote:
Dear expert,
Any suggestion?
Kind regards,
Giuseppe
