3.5 compiling, round two
OK, the lights are on, the phones are workin'. Let's try this again.
So, I got Francesco's binaries working. Folks, I have no idea what happenned to my RAYPATH. But I put a line for it back into my .profile file and it worked. So, of course, I then uninstalled the whole thing because I'm stubborn and want to compile the source, darn it!
I (believe I) removed all traces of Radiance from the /usr/local/bin and /usr/local/lib/ray folders, essentially starting from scratch. Schorsch, thanks for that tip on redirecting the output to the file, it worked a treat. (BTW, I *had* to use the second iteration "makeall install |& tee log.txt" so that I could answer the prompts).
Got errors again, but after combing through the log they all center around a few things during the compilation of the holodeck stuff. Here are all the errors (I ignored warnings for now):
gcc -I../common -L../lib -O2 -DSPEED=200 -Dlinux -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGMEM -c -o rholo3.o rholo3.c
rholo3.c: In function `dispbeam':
rholo3.c:92: parse error before "else"
rholo3.c: In function `ambient_list':
rholo3.c:272: parse error before "else"
rholo3.c: In function `sortcomplist':
rholo3.c:393: parse error before "else"
make: *** [rholo3.o] Error 1
gcc -I../common -L../lib -O2 -DSPEED=200 -Dlinux -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGMEM -c -o rhpict2.o rhpict2.c
rhpict2.c: In function `reset_flags':
rhpict2.c:263: parse error before "else"
rhpict2.c: In function `meet_neighbors':
rhpict2.c:339: parse error before "else"
make: *** [rhpict2.o] Error 1
make: Target `install' not remade because of errors.
and, of course, the dreaded:
There were some errors.
I now have 113 binaries in /usr/local/bin/ray, but the binary package at radsite contains 135, I believe. So, I guess I'm close, but no cigar. Any ideas?
      Rob Guglielmetti
e. [email protected]
w. www.rumblestrip.org
